The_Chemist
- Sep 12, 2018
- Location
- Swatara Township, Pennsylvania
I have a question for those who's trucks are equipped with 4WD Auto.
My truck makes a sort of groaning, grinding or scraping noise when I engage 4WD Auto. The noise gets much louder when I make a tight turn. It almost sounds like the oil is dry. It also gets much louder with my foot on the gas.
The Chrysler area manager supposedly drove my truck and said all the noises are normal because I tried the system on dry pavement.
I was prompted to try the system because my rear differential is defective, was rebuilt by the dealer and now is going to be replaced as a new factory assembled unit in its entirely, because the dealer repair failed miserably.
The area manager wrote a statement on my last service work order saying that the 4 WD Auto system was not designed to be used on dry pavement.
I think that's total BS.
I'm going to paste a section from the owners manual below that states otherwise:
"This electronically shifted transfer case is designed to be driven in the two–wheel drive position (2WD) or four-wheel drive position (4WD AUTO) for normal street and highway conditions on dry hard surfaced roads). Driving the vehicle in 2WD will have greater fuel economy benefits as the front axle is not engaged in 2WD."
Dors anyone else who has this system hear any kind of noise when it is engaged in 4WD Auto especially when making a tight turn?
I normally keep the truck in 2WD, but this is what I experienced when I tried 4WD Auto for the first time. I do believe mine is defective.
What would be the point of having 4WD Auto if it weren't designed to be left on in anticipation of bad weather?
I've owned 2 other rear wheel drive based vehicles that had 4WD Auto which made zero noise when engaged.
I think the dealer and area manager are feeding me a line if BS!
Any input is appreciated.
