diamondmi
Installed 2” rear lowering springs and a hellwig sway bar. What a amazing difference. No more water wagon feel every turn or lane change and still has that stock comfortable ride.
I asked about the sway bar on my Laramie Longhorn and was told I have one from factory. Is the Hellwig just that much better than the stock one? Do you know why?
Waiting for my newly ordered 2020 Laramie Longhorn, Delmonico Red, chrome bumpers, 20” wheels, 5.7 V8 Hemi MDS VVT eTorque, 3.92 rear, all options except diesel, multifunction tailgate, protection group and trailer tow group. Interior Black/New Saddle. Looking forward to delivery. Truck arrived!!! Yes!
Ellisstrong
Atlanta Ga area
Do a search on here for hellwig sway bar. Lots of people on here feel the same way about it.
acbone710
Removed the front air dam and active aero. The air dam takes up 6" of clearance at it's lowest point.
Oh and I cut and drilled for some universal mud flaps. I didn't like anything available for our trucks.
97bd18cf-197c-4b69-9667-a12fd14365b5-jpeg.35423
895c9f20-94b0-431f-9b69-ec641f484319-jpeg.35424
Short vid before I did the weekend work to the truck:
I have been wanting to remove the air dam for a while and finally decided to give it a shot after seeing your post. How do these connectors come off? I've never seen one quite like this and don't want to break anything.
Sent from my SM-N950N using Tapatalk
Edwards
TX
Looks like a black nut up on top that you need to loosen. The bolt is captive. No idea why they went this route.
CFCSW6
New Ram owner here. This forum has helped a lot in the purchase of my new truck.
2019 Laramie Longhorn.
Added front window tint to match the rear.
Just installed 33x12.5r22 Nitto Ridge Grapplers today. Absolutely love them. They look great, not much road noise. They rub ever so slightly at full lock. Tiny cut to the wheel well liner will take care of that. Pictures are in entry and off road 2 suspension settings. 20190910_112038.jpg 20190910_112239.jpg 20190910_112250.jpg
barakutha
Just installed 33x12.5r22 Nitto Ridge Grapplers today. Absolutely love them. They look great, not much road noise. They rub ever so slightly at full lock. Tiny cut to the wheel well liner will take care of that. Pictures are in entry and off road 2 suspension settings. View attachment 35548 View attachment 35549 View attachment 35550
Looks great.. time for a little leveling with the revel links and Daystar spacers
W13NY
New York
Interested in doing a level soon - wondering what an average cost should be for something like that (parts & labor). Never had a truck til now so I'm unfamiliar.
barakutha
Parts were approx $250, and labor the same
AnthonyD1978
Prescott, AZ
There is a 10mm nut on the top of that. Loosen it and remove nut. The small metal bracket stays on.
flynfish
Do people usually have a dealership do it or lift shop? Is there normally a cost difference between the 2?
acbone710
You were correct! Don't know how I missed that...
For anyone else wanting to do this, start with the active air dam, there are 4 13mm nuts then just unclip the cables and it pulls off. Next, there are about 15 10mm nuts on the top of the air dam. Then there is a bracket on each side with a 10mm bolt and a plastic push on connector on each. Remove those and make sure to unhook the wires that are tied to them. Finally, there are three plastic clips that you will need to remove by squeezing inward from the top and pushing through. That should release it and it will drop down.
I've got a 2000 mile trip planned for next week so I'll report back on any changes in mpg.
Hockeydad
SoCal
The Hellwig is solid steel the stock hollow you can totally tell the weight difference.
Matthbert5150
When. I purchased mine (still waiting on delivery), the lift wheels and tires were rolled into the finance. I know the general manager at the dealership and also the guy who is doing the lift and stuff. I'm actually saving about $1000 doing it this way.
But I've seen dealers mark up the price of the lift wheels and tires just to make it a premium option.
barakutha
Not a lot of places currently work on air suspension, you'll have to look around
2019 Limited 4x4 with Rambo, no etourque
- Leveled with Daystar spacers and revel links
DrAudio
Picked it up this afternoon and signed the papers after they put new shoes on it!
The new 2020 Limited with black appearance package and had Nitto Ridge Grapplers put on before delivery.
