Has Anyone Tried the Weigh Safe Hitch Ball?
I had a weigh safe drop hitch and it worked great. Towed a 10,000 pound trailer where hitch weight could vary a lot based on how it was loaded.
Here is some discussion about it. A few other posts do as well.
I think it’s a great idea however if you use an anti rattle device it won’t work. Since the anti rattle devices press the shaft of the hitch into the receiver, the weight sensor will not work.
Just food for thought if you use an anti rattle device
I've been looking at these. For those with a non-lifted 1500. What drop/raise did you buy on the adjustable?
I have a 4” drop that was on my F250. I bought a new 2” shaft to convert it for my 19’ Limited. Probably about right in the upper holes but all trailers are different. Good hitch but pricey
I think this is a good idea but I don't have a chance to try it because I bought a hitch Clamp Anti-Rattle for my trailer. It is a good hitch which is easy to install and compatible with the most model and makes of vehicles. Someone can try it.
Possibly not going to have the space to use if you have a WDH
