Dodge won't admit it as they don't make pickup trucks...RAM does![]()
But they have to as the Durango is just as bad.
Did any of you with valve hack noticed that air blows with less force and sound with valve closed vs. Open valve for the same blower speed?
I'd probably go with this one, as it's specifically designed to control coolant flow to/from a heater core - so I doubt it'll melt down:After unusually high temperatures I'm a bit fed up with the AC but I'd really like it to be able to open and close the valve from the cab. I went out the other night time and wanted the heating on so it would have been a nuisance to stop and open the valve under the bonnet.
I'm thinking of fitting an electric valve with dash switch so I can have it fully closed for my own version of MAX AC or open to use the AC/heater as normal:
I think this should work OK as designed for auto use with anti-freeze but I'm a bit nervous that it can only handle temps of 110C/230F.
Around 210F seems to be around half way up the gauge, I'm not sure how linear the gauge is but if the engine did start getting hot the max of 230 doesn't sound that high and if the valve melted it would be a disaster.
Any thoughts please?
I have a 2020 and it is not cold by any means. I haven't checked temps yet, but definitely not as cold as my other vehicles.Has anyone tried the AC in a 2020?
Vintage Air 461171 Vintage Air Replacement Heater Valves | Summit Racing
Free Shipping - Vintage Air Replacement Heater Valves with qualifying orders of $109. Shop Heater Valves at Summit Racing.www.summitracing.com
Simple 3-wire hookup - black to ground, red to a switched +12V supply, and blue to your in-cab switch (which is also wired to a +12V feed).
Let us know!I have a 2020 and it is not cold by any means. I haven't checked temps yet, but definitely not as cold as my other vehicles.
Thanks for the replies, I was trying to find one the UK to avoid import, its probably best Summit isn't in the UK or I'd have bought an engine for a reject car and all sorts by nowAnd it uses 5/8 heater hose which makes it even better.
So my truck is back at the dealership for the AC again, they finally decided to clamp off the heater core and confirm the AC temps. 38 at the compressor and 43 at the vents. They said this proves that there is something going on in the plenum (airbox) they want to pull the dash and check but with no codes from the BCM and the dozens of people on here with the same exact issue it would seem to me that its a design issue more than a faulty part. I dont think I am going to let them pull the dash.
If you are not willing to pull the dash, can you ask them to recalibrate the blend door actuator. I have not heard of any dealer performing this yet. It could be a simple fix.So my truck is back at the dealership for the AC again, they finally decided to clamp off the heater core and confirm the AC temps. 38 at the compressor and 43 at the vents. They said this proves that there is something going on in the plenum (airbox) they want to pull the dash and check but with no codes from the BCM and the dozens of people on here with the same exact issue it would seem to me that its a design issue more than a faulty part. I dont think I am going to let them pull the dash.
I would ask if they can snake a camera on a cable down into the plenum before the dash gets pulled apart. Take the air cleaner out behind the glove box and enter from there. Shine a light up from the floor vent on the driver's side. If you can see light from below, good chance that will point in the direction of the fix.So my truck is back at the dealership for the AC again, they finally decided to clamp off the heater core and confirm the AC temps. 38 at the compressor and 43 at the vents. They said this proves that there is something going on in the plenum (airbox) they want to pull the dash and check but with no codes from the BCM and the dozens of people on here with the same exact issue it would seem to me that its a design issue more than a faulty part. I dont think I am going to let them pull the dash.
