Looks great, was the C-Quartz easy to apply/get on even?
Thinking about doing mine but don't have a garage but that doesn't look necessary with the C-Quartz, also I wouldn't want to create a mess by getting it patchy or something.
C quartz was EASY! literally wipe on, wait a minute, wipe off. Wait 60 minutes, add coat 2. wait 60 minutes spritz with 'Reload'. Waxing a car is harder than applying C-Quartz UK. I used up about a third of the 30ml bottle for 2 coats. I took the extra and did the wheel well liners, plastic shroud in front of engine/behind grill, and exhaust tips. Still have 1/3 bottle left.
Ceramic tint Pano roof, back doors and rear window. Hoping this helps keep the heat down. I did the front windows and brow last month and didn't think about the factory tint not cutting out the heat. From what I have heard on here installing the ceramic over the factory really helps. Will be heading back to W Texas in a week and will see how it does.
I installed ceramic tint all around except for windshield and the reduction in heat is OBVIOUS! One of the best things I could have done for the truck.
RB20 running boards, husky mud flaps, swapped emblems for black ones, painted the hood ones, replaced white sticker with black.
My new wheels arrived Woot woot..
20x10 - 18 offset Fuel Warrior
Waiting on some other goodies to arrive in the next few days...
Question? Did you have to do a lift kit for those wheels and tires?
Thanks
Installed the Husky mud flaps.
Do u have the fender flares? How do u like the mud flaps I saw some on their site but it only showed with out fender flares
What brand did you use? Pretty easy to do?
I do have fender flares and FYI, they’re not the painted flares.
Oh forgot to mention also installed the PedalCommander. So bleeping sweet! Sport+ scared me.
and they thought I was crazy when I asked FCA to put the SPORT mode button and tune in the rig as part of the SPORT PACKAGE .. :)
Took it to a tint place to have it redone due to specs trapped under the film...turns out those specks are embedded into the cab side of the windshield from the manufacturer. Also my turn signals now activate my panic alarm and my radio has been playing dual audio sources at the same time
I have been trying to clean my windshield for weeks. I can't tell if the spots are on the inside or outside...I'm wondering if they are embedded like you mentioned.
It's been driving me nuts lately.
1 installed the bed divider/extender pieces my local dealer ordered for me :
34945
34946
2 installed the "Limited" open lower grille
34947
3 started cutting up the main grille to install the dual 6" LED kit -- there are a few errors in their instructions that I have found at least with my rig. I was going to just use my Phillips DRL setup (they are small enough profile to not have to cut up the grille, AND they have a SENSE wire that when your running lights are on, the LEDs DIM to be used at night on the road. Too late now, the grille replacement would be nearly $700 for the main part (of 3) that you have to cut. Finishing up this morning after I verify alignment prior to reinstalling -- you can't align them after the 3 parts of the grille are put back together on the Tough Country version.
34983
Was the bed divider/extender supposed to come with that hardware or do you have to order that separately?
Do u have part # for the divider/extender hardware. How much make sure dealer dosnt stick it to me
yes/no/yes/who knows .. my dealer and I both thought the parts would come with it .. they were awesome enough to add them since they were under $50 for all 4 parts. There is a Star Case open that if anyone submitted a request under warranty, etc., FCA would deny the claim and force the end user to purchase the parts. It is in the video on the showroom floor. plenty of posts here :
please see above .. they've been listed a few times, and I don't wanna repost and have information in too many threads :)
I tried to also plastidip my deflector and upper grill but failed miserably (I applied the last couple coats way too dry).
Luckily just peeled right off with no residue
