So exited to finally have this truck. It looks even better in person when you first get to see it.
With a 33 Gallon Tank my till empty was 487 miles. I was around 15 MPG heavy stop 'n go for about 20 some miles total.
e-Torque stop/start was great and did not bother me at all. You will feel a small vibration when it shuts down at a light/stop, and then takes right off. You only hear the exhaust fire up on the start, no sound from under the hood...unusual sound that is.
Ride quality with windows up is quiet. Have to strain to hear engine when cruising. I was worried about the tire sounds with stock Rebel tires, but sounds no more louder than my car did..perhaps even lower.
A/C was working great in about 93 degree weather with some humidity.
9-Speaker system with Sub sounds better than what I had in my Mustang, and the sub will put out bass. I had 12"s in last car and Alpine sub performs well in the truck.
The Truck has an Automatic Parking Brake option(sets every-time in park on auto), you can turn it off through U-Connect. All you do is lift up on button to set, and push down to release it. I do it manually.
Extra feature I learned from Salesman: If you leave your keys in the vehicle and try to lock it...it wont lock(lights/horn sounds once). If you leave your keys inside and lock it from the inside, when you shut the door lights/horn sound 3 times and door automatically unlocks.
