I used my key fob to lower my truck to E/E yesterday. This morning, I got in and drove to the gym, parked for a while, then to Chick-fil-a, then home. I saw 52 MPH on the speedo on the way to the gym (as my max that I saw). I was over 30 MPH for most of the 10 minute trip to the gym. Ditto for the 15 minute drive to CFA and then home. It stayed in E/E for the entire round trip.
I do believe it is what some of y'all have said. If you lower it to E/E with the key fob, it just stays there, no matter what.
Other observations:
- The Owner's Manual section on Air Suspension is wrong on several details.
- I can use the toggle to raise it up or lower it in 5 different positions. E/E, Aero, NRD, OR1, OR2. That all works fine (and seems to conflict with at least one post here that said you can't manually put it in Aero mode).
- Before having it "stick" in E/E, I had manually hit the toggle to put it in Aero mode. It has stayed in Aero mode at all times. When it was set to NRH, then it would go in and out of Aero mode at the appropriate speeds. I don't have running boards (yet), so having it stay in Aero mode makes it a little easier to get in and out. I wish there was an option to have it automatically lower to E/E any time you shut the truck off. Then I would leave it in NRH all the time. And maybe not feel a need to add running boards (and maybe that's why they don't have that feature?).
- It is pretty easy to hit that ride height toggle switch by accident. I've done it several times when putting my phone in or out of the wireless charging slot (and I've had my truck less than 2 weeks). I wonder if people who are saying their truck gets "stuck" in Aero mode are simply accidentally manually toggling it into Aero mode and then that's just where it stays. Maybe there's nothing wrong with the truck - it's just that the manual is wrong and dealership people don't know that it's working the way it's supposed to.
- I will probably mention it to my dealer at my first service, but if the only thing "wrong" with the air suspension is that it stays in E/E if you put it there using the key fob, I think I can live with it.
