Lablvr2
- Dec 4, 2018
I posted this a while back and it may not be the cause of your leak but worth looking into. I have talked to several other owners that had front carpet leaks that originated from the rear drain grommets like mine did.I went and visited the truck today. It was in a body shop with the front fender removed. They did a nice job of applying seam sealer to a joint that was way forward of where the water was coming in as well as it was below the bottom of the windshield. They said they will water test on Monday.
If not watertight, they will remove the windshield.
They didn't say they tried pouring water on that joint before sealing it to see if it could be the source of the leak...
We will see, but I think they will have to pull the windshield...unless maybe my understanding of gravity is wrong.
Gerry
Water leak and wet carpet (solved)
I apologize ahead of time for the slightly long post. By posting this I hope in some way to help some of the folks who are frustrated with the mystery water leaks on these new 5th generation Rams. Recently I discovered my driver side footwell carpet was slightly damp. I finally had some spare...
5thgenrams.com
