Front bumper alignment
EddieB
Houston, TX
Well I got my truck back from the dealership. They had a traveling master tech from FCA take a look at it since this was the 3rd try at getting it right. He inspected the truck, took several measurements and deemed it 4mm off left to right "well within spec" . What a bunch of BS. I guess I'll just have to live with it. At least its a lot closer than it was
I cannot believe this manufacturer pushes out vehicles like this. I have had 4 vehicles from this manufacturer and this is the LAST. I Can’t wait to get rid of this truck
moosem
Rhode Island
As time has passed, it’s bothered me less and less and I don’t even think about it anymore. I’m just enjoying the truck.
It’s not perfect, but it’s a lot better than it was pre-adjustment, and it’s not noticeable unless you really scrutinize it.
Todd
Central NC
Mine was readjusted to my satisfaction, by the body shop my dealership took it to. Appearance isn't even noticable now. Not sure of the work preformed.
MechanicCor@dodge
Alberta Canada
Anyway I could get the phone number to the bodyshop you took your dodge to? Be nice to have a chat with them and see what they came up with. Cause the body shops in Alberta are garbage haha
Im located northern Alberta Canada and we are having the same problems. Ive adjusted the grill to where im happy. Doing some fine measurements I have noticed that the passenger side Facial (under headlight) is 1/4 difference in size compared to the Drivers side measuring at 6". passenger 6 1/4"
Only some people notice this issue but to me its not right. I wanna fix em all to at lease get em 99.9% cause with having bodyman experience I can def notice them...compared to your average Joe. still isnt right tho
Todd
Central NC
At your request, here you go!
jcvick284
Hi Todd and moosem,
We regret to hear that you are both experiencing this. Please send our team a private message if you would like some additional assistance while your trucks are at the dealership!
Alex
Ram Social Care Specialist
jcvick284
Hi Todd and moosem,
Alex
How would I go about sending a private message to Alex?
I have a new 1500 Ram Bighorn with a crooked grille and I’m having lots of problems finding a dealership with a body shop that can align it correctly.
moosem
Rhode Island
Click on the "Ram Cares" avatar and then click on "Start Conversation+
Click on the "Ram Cares" avatar and then click on "Start Conversation".
EddieB
Houston, TX
Mine has the same issue. Bad machining on front bumper. You will need bigger bolt holes to get more adjustment. Mine didn’t have that much play.
jcvick284
So I’ve been reading all the posts here about the grille being misaligned and at the same time, trying to find a dealership that had a body shop and knew what I was even talking about. Mine was off about 1/2 to 3/4 of an inch side to side, the passenger side being lower than the drivers side.
I had found a you tube video about how to remove the grille and thought what the hell, I’ve give it a shot. Long story made short, the facia panel was a bear to remove, but when I got that off, 3 bolts loosened and a padded pry bar between the bottom of grille and bumper to move the grille and retighten bolts, and we’re now even side to side. Probably took the better part of 2 hours, but now at least I can walk to the front of the truck and not grit my teeth. I wish I hadn’t had to fool with it, but I wanted it fixed right,and as the old saying goes, if you want something done right, just do it yourself.
ermil1385
My Laramie Sport Crew 4X4 has a slightly different bumper/grille issue than most of you; The bumper appears to be higher than normal (or the grille lower) as most Rams I see have a gap between the bottom of the grille to the top of the bumper. Mine appears to overlap. The gaps between headlight fascia and bumper appear pretty even, and gap between grille and hood is small and even, but the "pushed up" bumper makes it look (to me at least) like the ends of the bumper (by the fender flares) are drooping slightly.......like the whole bumper is twisted upward slightly. I think it is an optical illusion but it is bugging me.......I'll try to upload pics today. Truck has 800 miles, just noticed it watching it come out of the car wash the other day...now every time I look at it that is all I see.......
Helmetface
Share the video link please?
My 1500 with less than 100 miles has this issue. June build date...
Of course, I go over the truck head to toe at the dealer and finally notice the gap later that night, long after I left. Glad I found this thread afterwards.
jcvick284
Here is what I found and used for reference
  • Grille - Removal and Installation.pdf
HollowBeers
I have my eye on the same kind of used Sport with the same issue. I don’t think it’s an optical illusion.
I have my eye on the kind of used Sport and it appears to have this same issue. I don’t think it’s an optical illusion.
ermil1385
Here are some pics of the misalignment...am I crazy? I just took it into the dealer for this and a bunch of other stuff.....they kinda rolled their eyes at me.....
34009 34010
chois
Glad to find this thread.
Just picked up my Big Horn from the dealer, who verified the crooked bumper, confirmed that there was not enough play in the bumper mounting to adjust it, and suggested they could take it to a body shop.
I'll follow up with them and ask that they start with the body shop verifying the grill to be square, and then adjust the bumper alignment pins as needed from there.
RamCares
Michigan
Hi chois,
We're sorry to hear that you are experiencing this alignment concern with your new Ram. If you would like, our team would be happy to connect you with a Case Specialist to work with you and your dealer to address this. We are available via private message.
Alex
cjlaredo83
My truck has been at the dealer since August 28 to correct the front bumper/grille alignment problem and a separate problem with an exposed weather seal around the passenger rear brake light. When I arrived at the dealer the service writer agreed both problems were legitimate and not correct from the factory. He added that it was normal on new vehicle models for there to be some things that needed to be tweaked but that they have an in house body shop and it should be no problem for them to correct.
It is my belief that the brake light issue has been fixed but the "face only a mother could love" is another matter entirely...
Nearly a month in and all I keep being told is that they agree the front end/fascia is misaligned but that they don't know how to repair or correct it. They even told me they walked the lot and found about 7 other 1500's on the lot with misaligned front ends. I have given them a lot of information I found on the forums (including links they could read for themselves) about how the problem has been corrected for others but they seemingly just ignored that. You would think with so many owners having this problem there would be some sort of bulletin from FCA to dealers on this by now with repair procedures. As it stands right now, the dealer is asking me to call FCA about the problem.
RamCares
Michigan
Hi cjlaredo83,
We're sorry to hear that you're experiencing this as well. As mentioned to your fellow forum members, we would be happy to get you connected with a Case Specialist to work alongside your dealer to address this. Please send our team a private message.
Alex
