Automatic high beams and Automatic rain wipers.
After all those vehicles I bought (and most of then are packed with these similar technologies or even more advanced than this) none of those issue ever happened on those cars except this truck. Yes, a bad sensor, windshield issue or software issue could cause the problem BUT it also shouldn't happen on a brand new vehicle.
and FCA is infamous for its terrible electronics quality controls. (Check out Alfa Romeo Giulia)
Well...if that’s your belief, you knew this going in. No offense, but why’d you buy a Ram?
Got the most equipment and the best interior in the class my budget can buy. F150 and Silverado are either interior is too outdated or don't have the tech I need.
Mine work largely as expected. It doesn't need to be super dark. What I find to be annoying is I need to have the turn signal stock in the forward position, which takes it out of range of my fingers when I want to signal a turn.
^^^this... mine work great, but disabled them for this reason
According to the Owner's Manual you have to do more than just activate the high beams in UConnect.
To Activate
1. The Automatic High Beams are enabled through the
Uconnect system. Refer to “Uconnect Settings” in “Multimedia”
for further information.
2. Turn the headlight switch to the AUTO headlight position.
3. Push the multifunction lever away from you (toward
front of vehicle) to engage the high beam mode.
To Activate
Yep. And you'll know if you did it right, since the cluster displays a message confirming this when you push the lever into position.
Mine seem to be working fine but my wipers skip at the top/full extension. Only had it for 3 weeks and 1100 miles. Truck was built in September though so maybe they are just getting old and/or sitting in the Florida sun that long without use messed them up. I’ll ask my dealer.
Sorry for these revival but my issue pertains to this.... but my automatic high beams aren't working and I'm getting a CEL that says Implausible Data Received from AHBM, B2854. Any ideas what could cause this?
Both systems work in my truck. The rain sensing wipers work great—better than on my BMW. They seem to adjust to the level of rain progressively, where on my BMW the wipers are a tad too sensitive. On the other hand, the automatic high beams on the RAM are too sensitive and are easily confused by reflectors or miscellaneous lights along the road, so it constantly switches between low and high beams. That system works perfectly in my BMW but in the RAM it can be very annoying.
I'm guessing since I'm familiar with Ram/Chrysler terminology, but AHBM probably stands for Automatic High Beam Module, except, I do not see a reference to it in the Service Manual. The system description only mentions a Automatic High Beam Control which interfaces with the Body Control Module (BCM). Just another guess, but I'm suspicious that the automatic high beam circuit or module is not talking to the BCM.
Sorry I can't really help you. I think a trip to the dealer is required.
Best regards,
Dusty
2019 Ram 1500 Silver Billet Laramie, Quad Cab, 2WD, 5.7 Hemi, 8HP75, 3.21 axle, 33 gallon fuel tank, 18 inch wheels. Build date: 17 April 2018. Now at 018460 miles.
So I have a 2019 Ram Sport. I am also having issues with the high beams. I have it turned on in Uconnect. I initially get the message that Auto high beams enabled. But they do not turn off when vehicles are oncoming. They will turn off when I slow down enough. Then randomly I'll get the message automatic high beams disabled...and that's it, they will no longer switch on. At all. Even with the stick forward, and the setting showing it's selected. So currently I don't have it enabled. I upgraded from a 2015 ram...and they worked there
But I'm also having issues with my park sensors randomly kicking it when nothing is around....so I wonder if I need a firmware upgrade (going to attempt that tonight).
Sent from my SM-G973W using Tapatalk
the blue indicator went on , so I am sure it was high. Plus I can see the differences when it light are projected on the road.
@Scarittagle, Sorry to drag up an old post but did you ever get this fixed or figured out. I just got my 2020 and am having the same issue. It is enabled in Uconnect, the headlight switch is on Auto, but when I push the stalk forward the high beams just come on and there is no message on the gauge display.
Did you ever figure out the problem. Having same issue with a 1 day old 2020 Limited. On in Uconnect, Switch to Auto, Lever pushed forward but still no message in display that it is activated and hi beams just stay on when approaching other cars.
Same problem here. Anyone have a dealer response on this issue? Thanks...
Just got my truck back from the dealer for this. It is working now, it sounds like they just did some sort of reset/re-initialization on that module that controls the auto dimming high beams. Hoping that it sticks and I don't have to bring it back but working for now. It was only there for an hour. I would get a hold of your dealer and have them try the same.
Thanks so much and will do!
I have the same issue. Just bought it last Friday... in the dealership now...
Would love to know if this reset can be done without going to the dealership. Anyone have any ideas?
Your rebel has the same problem too? Ahhh man... I have a Rebel 12 2020 as well...
