Hey Guys and Gals, I just finished my upgrade on a 2019 1500 crew 8.4' Non-alpine system using all the information posted on the forum.  First, let me start with a great appreciation for those who have paved the way for this upgrade. Without your trial and error, and knowledge, this would not have been possible. Therefore, thank you!
In the 8.4 system, there is an Active Noise Cancellation device Crutchfield is calling an amp. It's not an AMP, it's ANC. There are two connectors on this device, input, and output. The smaller connector in the input from the radio, the larger connector for the speakers. You can tap into these for all your wiring needs, just use the proper wire splice connector.
I used the Audio Control LC6I DSP for $100 on amazon,
Simple to use and easy to install. I mounted mine under the seat, but don't mount it on top of the ANC there is not enough clearance.
You'll also need the 50 Ohm resistors, installed on the positive leds from the Radio, this will keep the radio from turning off. Again, this information can be found in the forum.  Additional, you WILL have to disconnect the Mic's that are located in the headliner. These stupid things will reek havoc and produce a boom hum from the speakers. Simple solution, again found hear in the forum, depinned or cut the wires on the larger connector attached to the ANC. I worked for two hours trying to depin, and in the end, I just cut one wire from each mic. problem solved. Used the diagram..
I purchased my speakers from Crutchfield, all speakers are Kicker KS and CS series. 3.5 in the dash with 150Hz bass blocker capacitors. Metra wiring connector from CF. WARNING. These are wired with reversed polarity and will need to be changed. Also, CF wiring diagram in currently incorrect. Don't use it... The correct wiring can be found here in the forum... Thank you to whoever posted it, that was a big help!
For the front doors, I used Kicker KS series 6.5' components with the supplied adapter from CF.
For the rears doors, again Kicker KS Series 6x9.
Foxacoustics makes an excellent enclosure for under the rear seat. It's worth $200. I've built subs for years, and this my first in a long time being purchase.
I used Rockford Fosgate R2D2 10" subs leftover from my previous install. Good subs for the money. under $100 ea.
Crunch AMPS for the Subs and Coax, again leftover from the previous car. I mounted the amps behind the rear seat in the crew cab. There is plenty of room for two average-sized amps.  Seat removal is easy with the correct Star Socket... Don't use a 12 point socket...
For less than $500, I now have a Kick *** systems. Still needs some tweaking... I have listed a few items if you are interested.
Amazon Audio Control LC6I
https://www.amazon.com/gp/product/B002T4XR78/ref=ppx_yo_dt_b_asin_title_o05_s00?ie=UTF8&psc=1
Resisters
https://www.amazon.com/gp/product/B07CWRMPG3/ref=ppx_yo_dt_b_asin_title_o06_s00?ie=UTF8&psc=1
				Amazon.com: 140 PCS Insulated Fork Spade U-Type Wire Connector Electrical Crimp Terminal: Home Improvement
					www.amazon.com
				Buy 130pcs 3:1 Dual Wall Adhesive Heat Shrink Tubing Kit, 6 Sizes (Diameter): 1/2, 3/8, 1/4, 3/16, 1/8, 3/32-inch, Marine Wire Sleeve Tube Assortment with Storage Case for DIY by MILAPEAK (Black & Red): Heat-Shrink Tubing - Amazon.com ✓ FREE DELIVERY possible on eligible purchases
					www.amazon.com
				Buy InstallGear 14 Gauge AWG 100ft Speaker Wire True Spec and Soft Touch Cable: Speaker Cables - Amazon.com ✓ FREE DELIVERY possible on eligible purchases
					www.amazon.com
Speakers
				3-1/2" 2-way car speakers
					www.crutchfield.com
				CS Series 6-1/2" component speaker system
					www.crutchfield.com
				CS Series 6"x9" 3-way car speakers
					www.crutchfield.com
Big thanks to everyone who posted in the forum.
