Patsy1099
- Jan 5, 2019
- Location
- People’s Republic of New Jersey
If you are tapping the speaker wires on the input of the ANC you will not need to do anything further with ANC, I will be disconned. At this point you want you load resistors on each ch. into your DSP. I highly recommend going into a DSP before feeding Amps. Otherwise you wont be cleaning and flatting your levels and you'll end up very unhappy.
That’s helpful. So just to confirm. If I wanted to do everything at the anc I could:
- disconnect the anc and completely remove it. Toss it in the garage.
- grab the wires from the white harness and either put on resistors OR buy a harness like yours with resistors
- connect that thru a dsp lilenthe fix 86
- fix86 to the amp
- amp to the speaker harness from the old anc (small gray harness)
- no need to do anything with any of the canbus wires? You still have all radio/eq/Bluetooth/ handsfree functionality?
