riccnick
3.92 with 8 speed loses 1-3 mpg vs 3.21
Who told you that?
I have a 3.21 truck with eTorque (but a 4x4) and I get 14-15 city and nowhere near 21.5 on the highway.
Who told you that?
Like I said this was best so far with 4,000 miles, usually see around 17 on Houston highways, this was a moderate 65-70 mpg drive over flat terrain. Reading all the threads the 3.21’s are the better performers being reported, especially on highways where can stay under 2000 rpms at higher speeds than th 3.92.Who told you that?
That shouldn't happen, not with that weight.Took the camper to Yellowstone last week and quickly realized that its cheaper to fly from now in with the new truck. I was also losing speed on a 5% grade. 21ft mini lite at about 5k lbs. Seems odd considering the tick is rated to pull 11.5k lbs.
It will suck gas at 75mph! Shouldn’t be towing that fast and it would certainly do better even at 65.That shouldn't happen, not with that weight.
225 miles on the truck and only averaging 8.6 MPG. Live in the suburbs, commute to/from commuter lot about 8 miles each way. Plenty of stop lights. But it's not the "City". It is a suburb area and you can occassionally cruise between 45 and 55 on long stretches. I certainly wasn't expecting 15mpg like the sticker says, but 8.6? Sure seems awful low. The same V8 Hemi in my Charger was getting almost 17mpg with the same routine, and with that car, I was always driving in Sport Mode and taking off like a rocket. With the truck, I pamper the s**t out of it, and getting half the gas mileage? Sure as heck hope this is the "breakin" mileage and it improves substantially. I was banking on 11 or 12mpg but don't see this truck every getting close to that.
Towing 75mph with cruise control engaged in the hills/mountains is probably a bad formula for mileage.Yeah, that image showed 75 as we were in South Dakota with 80mph speed limit. But through Minnesota and Wisconsin doing 65-70 got home with 5.4mpg on the clock. Same type of driving with my 14 Ram Sport got me 8mpg with same camper and never had my foot to the floor in the 3 years of towing with it. I averaged 16 daily commute with the 14 and now 13 babying the 19. Something has definitely changed. Trailer tires are rated to 87 so not really sure why I shouldn't tow at 75....
I think we have the best comparible trucks for the difference between the 3.21 and the 3.92. My Lie-O-Meter shows about 17.9-18.1 I am sitting at 20,300 miles now so I think the drivetrain is broken in.Scrolled down while checking tire pressures and then down to miles per gallon which I haven't reset in a while. Lie-O-Meter showing 20.4
What do you mean by getting the transmission to shift? You mean from like 7th to 8th gear? My truck is in 8th gear at 30mph. Yet on my Pacifica you have to be almost 50mph to reach 8th gear. Heck, in my Charger, it wouldn't go into 8th gear until I hit nearly 60mph. So while I was thinking that maybe it's good that the truck is reaching 8th gear so quickly it would help save me fuel. But now that I think about it, maybe that isn't right? Maybe it's shifting too quickly to 8th gear and trying too hard which is causing the engine to feel like it's hesitating and jerking me back and forth, and may account for the dismal 8.6 mpg I'm getting. I mean, I don't accelerate quickly, and I even try to take my foot off the brake and coast as much as possible. And I don't brake hard. But no matter how gently I try to coax the truck, the mileage has never shown above 10 mpg and currently sits at 8.6. So what is the verdict? At what speed should the transmission shift into 8th gear while driving? Oh, and by the way, if there is an ECO mode, I've NEVER seen the ECO light go on in my truck, so I have no idea if that's a bad thing either.The next thing to look at is your RPMs in certain conditions. I have noticed that sometimes driving 45 MPH I am getting 15 MPG on the dash, but if I apply the accelerator to get to 49 MPH i can get the transmission to shift and get 20 MPG. On the highway with 3.92 gearing anything above 70 MPH and my fuel economy drops. Also the poster above mentioned sometimes it is the operator that is the issue. I think my wife drives in circles all day and leaves her van running between stops because she only manages 19 MPG, and I get 22-23 every time I drive it and I have the skinny pedal to the floor the entire time to try to get that thing up to speed.
