One suggestion from my isolated point of view; i have the 110v outlet in my ram + usb outlets and if I was in your position, I would run 12v beneath the bench seat and affix a proper invertor and pair of 12v power plugs beneath the seat for a few reasons;
* when the seat is flipped up and i'm using the floor for boxes, I cant plug anything into the 110v plug because it juts out and the weight of items can clip/damange anything plugged into usb/110v
* with anything plugged in, i can't hide it and leave it plugged in -there's always a wire running from the console to the cupholders or under the seat
* trip hazard - again, anything plugged in is crossing the load floor which is just asking to be tripped on
my .02; I'd opt for a nice project box or utility panel under the rear seat bench
Good news--Bad news.... the good I got into mine without breaking anything .... the bad ---- the wire harness is NOT present for the rear media hub and 110v outlet... at least on mine, manufactured of 4/19. Next I need to get a hold of the rear wiring schematic to make my own harness. Anybody got that wiring diagram and want share, I am determined to make this work....
@K22---- The wire you show in your pic is present in mine, but that goes to the center consoles usb port ( under arm rest ). The harness for the rear hub is totally different from what I can gather from other pics.... As far as the 110v port is concerned, that will be an EZ mod... I really only want the hub so most of my energy will be placed there..
Crap, didnt even realize there was a usb under the armrest. Are you planning on running power and putting in the usb ports as well? Would be interested to see how. Im more interested in just adding the usb. Thanks!
Another option for those that just want a few extra usb's in the rear center hub where that cup/like area currently is location; you can opt for a usb splitter like in pic below. Run it from the usb located underneath armrest to the back as a quick fix if ya have crumb snatchers back there that need it fastlike:
Amazon.com: Anker 4-Port USB 3.0 Ultra Slim Data Hub for Macbook, Mac Pro/mini, iMac, Surface Pro, XPS, Notebook PC, USB Flash Drives, Mobile HDD, and More: Computers & Accessories
www.amazon.com
OEM will look better but this can fix it for the little ones for some peace of mind.
I'm glad to see that others are also trying this. I was hoping to also add USB ports and the 115v module to my Rebel Crew Cab, so for me I would need to replace the entire end cap instead of just the little cubby (the 115v module hangs down a little lower than my current end cap can fit). Once I removed the end cap a few weeks back to see what my options were, and also found that the only wiring I have is for the existing arm rest USB.
I can't find it now, but on one of the console swap projects that's taking place, I saw a cable cluster available on an oem site that appeared to add usb and 115v functionality, but you'd need to run it to your fusebox. If i recall correctly it was around $90.
The dollars are definitely adding up. One big concern I have is... if I buy the end cap that I need, I have a strong assumption that the usb and 115v modules aren't included and I'll need to buy them separately. Again, $$$. Does anyone know from experience?
Shop 2019 RAM 1500 REBEL Crew Cab 5.7L HEMI V8 Parts from MoparPartsInc.com in Myrtle Beach, SC, and keep your truck working its hardest.
www.moparpartsinc.com
AGAIN AS NOTED FOR ANYONE ELSE READING THIS YOU WILL HAVE TO BE VEHICLE SPECIFIC TO BE SURE ON YOUR PARTS...REBEL BIGHORN ETC...SOME MAY BE THE SAME AND SOME MAY BE DIFFERENT.
Select---Year, model etc...this way you can find your parts/numbers specifically for your vehicle--some parts are interchangeable others may not....this way you will know for sure.
So is this abandoned like others? I can't believe they want 300 bucks for the plastic. I'm leaning more toward the option that was mentioned that referered to building a box to go under seat with 12v USB and an inverter. Starting to sound like the more inventive and cost effective way to make it go. Any sparky's out there that know where an open fuse under the dash may be and what gauge wire would be needed to support this setup?
Sorry, got the part just haven't installed it yet. will be putting it in on Saturday. I will upload some photos of the part out of the box all the way through install.
www.amazon.com
Buy TNP USB 3.0 Flush Mount Cable w/Buckle, Dashboard Panel Dash Mount 1 Port USB Socket Plug Jack Connector Extension Wire Cord Water Resistant Male to Female (1M / 3FT): USB Cables - Amazon.com ✓ FREE DELIVERY possible on eligible purchases
this is awesome! could this be done on a Bighorn with lvl 1 equipment group? does anyone know? Can lvl 1 equipment group also add in the 115 V AC 400w plug? Can this be done if you have the front bench seating?
Hey guys, I have a 2019 All-new (not Classic) Ram 1500 Crew Cab, with lvl 1 equipment group, 4 wheel drive, 5.7-Liter V8 HEMI MDS VVT eTorque Engine, with front Bench seat.
Can anyone help me confirm/leave feed back that these are the right parts for adding the "Rear outlet and USB ports"?
Those look right to me but I abandoned this project once I started doing the math. The end cap alone at around $300 was too crazy.
I ended up buying 2 quick charge automotive USB ports and installed into my existing end cap using a forstner drill bit. Picture attached. Ironically, I’m wiring them tonight and have come to the realization that my internal power distribution center didn’t come with a lid, so I literally have no map of what each fuse is for. Owners manual essentially says to look at the lid. Just my luck lol. Can anyone please post a picture of their internal pdc lid?
Wow that looks awesome Prairiedoggn..... where did you get those "automotive USB ports"? Could you post the link to where you purchased them? I might have to do something like that too. Do the parts come with the wiring?
Sorry for the delay. Here's what I purchased USMEI Dual QC3.0 USB Charger Socket
I've been out of town and am about to actually hook up the wiring and go live. I'll tell you right out of the box the included cable is VERY thin and is also not long enough to reach the interior fuse box, so I purchased some 14awg from Lowes, and am going to run it to a Micro2 Fuse Tap that I purchased, fuse 65 if i remember correctly. What I'm hearing is that the negative wire just needs to be attached to the chassis rather than the fuse box.
I'll post results once I'm done.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
