TurdFerguson
- Sep 19, 2018
300 bucks? WTF?
Wtaching this one intently as well. I also have the same issue. 19 big horn crew can. Just want the usb ports in the rear, dont need the plug. Is the above link the part for me? Hoping the wiring is all there.Following also as I'd like to install the missing USB ports for the rear seat. I think you need #11 "BEZEL. Media Port." at https://www.moparpartsinc.com/a/Ram...WD/_55066_7543334/Floor-Console/i2381602.html to go with your media ports.
agburmeister, did you find that the needed wiring harness was inside the console or do you have to run your own power to the ports?
Looks like the usd port part is cheap enough but the bezeil to match is stupid expensive. Only thing I am not sure is if the wiring is in there. My guess is that its there. My Bighorn has empty plugs all over the place from the missing features I couldnt afford.Wtaching this one intently as well. I also have the same issue. 19 big horn crew can. Just want the usb ports in the rear, dont need the plug. Is the above link the part for me? Hoping the wiring is all there.
Yikes! I was trying to find the matching bezel but theres so many parts. About how much is that part do ya know?Looks like the usd port part is cheap enough but the bezeil to match is stupid expensive. Only thing I am not sure is if the wiring is in there. My guess is that its there. My Bighorn has empty plugs all over the place from the missing features I couldnt afford.
click on this link and go down to number 7....there are plenty of them as you would have to match it up to color scheme in your vehicle.Yikes! I was trying to find the matching bezel but theres so many parts. About how much is that part do ya know?
I removed the middle piece and can confirm the wiring is in there. If there was just a way to order the middle piece in between the AC vents that has the opening for the usb ports, we would be in business. Sounds like you might have to order the entire bezel though, but I cant tell. I searched the part on my truck from the pic below and cant find it. Looking at the parts online theres so many of them I cant tell if its possible to order just that piece, along with the usb switch. May stop at the local dealer and see if they can help at all. If anyone else can see where you can order just the middle trim piece please let me know!click on this link and go down to number 7....there are plenty of them as you would have to match it up to color scheme in your vehicle.
Floor Console.. 2019 Ram 1500 Big Horn Crew Cab 5.7L HEMI V8 4WD - Myrtle Beach SC
2019 Ram 1500 Big Horn Crew Cab 5.7L HEMI V8 4WD Floor Console.www.moparpartsinc.com
around $413 keep in everyone has the 15% discount from MOPAR which is good until end of year, so that will help reduce it some ($60-ish dollars less)
Can someone on here that has access to the instructions on removal post that in here please?
I have the level 2 which comes with them already, so I have no need to go inside there but hopefully one of you will do it and let the others know if the wiring is there?
What he said. I have yet to see anywhere the console breakdown and was concered with breaking it.@K22---how do you remove it... I don't want to break anything...
Following, just picked up 2019 Rebel and need those outlets...click on this link and go down to number 7....there are plenty of them as you would have to match it up to color scheme in your vehicle.
Sorry...to pull off...start at the top left and right by the ac vents, just try to pry your fingers under it and it should pull back, then you can work your way down. The bottom pulls out pretty easy too but the middle im afraid to pull any harder. Hope that helps.Alright I went back in, took a few more pics for everyone. I got to the point where I didnt want to pull any harder for fear of breaking the piece but you can see the wires below. I took a few shots of the trim piece pulled out but also where its still attached to the middle of the console. I cant tell if it will take a good pull from there or if Ill break something. Also, the middle piece inside the middle piece appears to screw in from the back. If you could just buy the small little housing unit you could just pull the piece out a little, unscrew the one in there and put the new one in, hook up the wires and I think it would be good to go. Wish I knew if you could only purchase the parts necessary without the entire bezel...??
I get the jist but do not know what a DTRT is.You can actually pry this piece up with a DTRT. Once it is up there are screws under it that will let you further disassemble the console. Might give you better access. I have pulled that piece but never gone any deeper.
I am determined to make this work....
