Annoying clicking sound in seat
2019Bhorn
Does anyone else have an annoying clicking sound in there drivers seat, At first I didn't notice it, but now I know its there, its all I ever hear, drives me crazy, I know I need to see the dealer, but there so backed up, that there is a chance I will be with out a car for a few days until the get around to looking at it...
alwi228
5thGenRams Supporter
Carmel, IN
Iiiii haven't noticed anything. Could you describe it a little more so I know what to look out for? Is there anything that makes it worse or better? Rattling? All seat controls still work? Electric components under the seat that are visible aren't knocking against anything?
2019Bhorn
All seat controls work, It almost sounds like the D rings for the ram box is moving and making the sound, but there not that loose, usually happens when I am at a stand still and hit the breaks, or gas, almost like a spring in the seat, but plastic sounding.
alwi228
Carmel, IN
RamBin*!!! Some people here would drive their cars off a cliff tonight if they knew you already had ramboxes haha. I will keep an eye out for anything tomorrow when I'm driving
2019Bhorn
Sorry, meant Ram Bin, lol.. Once you hear the sound, you cant unhear it, like like a ticking clock while your trying to sleep, lol
Chips
I was curious to see if you ever found any resolution to the seat clicking issue. I am experiencing the same kind of thing with my 2019 Bighorn. Very annoying and difficult to isolate to a specific area in the seat. Seems to be on the side facing the center console, mid to upper section of seat. It's starting to drive me crazy! Very subtle, but still hear it at low speeds when braking or accelerating in parking lot, etc. Aside from getting some recalls taken care of, I just dropped mine off at the dealer and mentioned about the seat. I'm not confident they will verify the issue unless it does it for them. Hoping I don't get the usual 'could not reproduce' response. Anyway, I was wondering if a root cause was ever determined. Thanks!
RamCares
Michigan
Hello Chips,
Did you hear back regarding your seats? Send me a private message if you need an added layer of assistance while in service.
Jasmine
Ram Social Care Specialist
ccookson
I have this seat click driving me nuts I’m very close to taking the seat apart my self !
ccookson
I have this exact issue driving me nuts !!
ccookson
Hello Chips,
Jasmine
Jasmine I need help I have the seat click dealer is not very helpful. Thank you
AndreiV
Southern CA
I dont have a "clicking" driver seat but my seat was wobbling or slightly moving around. In my case it turned out to be that one of the bolts was not torqued all the way and sit was rocking during turns, stops, and accelerations. May be check all seat bolts to make sure that they properly seated.
RamCares
Michigan
Hi ccookson,
I’m sorry to hear of the trouble you are experiencing with your Ram. Wanted to give you a heads up that I just sent you a private message regarding this concern. Please take a moment to review my message and follow-up with me there at your earliest convenience.
Mark
Fidomac
I believe I saw a post where someone had a broken weld in their seat frame and this was causing a clicking noise
20Rebel19
Canada
I have thg same annoying clicking sound but it's coming from my passenger seat which is a manual adjustment seat. Not getting it from my power adjusting driver's seat. Only happens when a passenger is in it and when making turns. I can duplicate the noise by rocking the seat left to right. Had a look under the seat while this is being done and it appears it is coming from the seat rail. Had it in at the dealer and they said there's nothing unusual. This is not normal, they just don't want to do anything about it. It drive me nuts. Thought I could fix it myself but I don't think so. Hope Ram comes out with a fix but I wont hold my breath.
Emtmatt
There are three "pins" on each side that activate with the sliding adjustment bar. Check yours, I bet these pins aren't seating properly. No matter which position (front to back) I put the passenger seat in, I can't get all 6 pins to fall in place - hence the noise.
RamCares
Michigan
Hi 20Rebel19 and Emtmatt,
We certainly understand why this may be frustrating. If you would like to have this documented and looked into further by a case specialist, please send our team a private message.
Alex
RamCares
Michigan
Same noise here.. :mad:
Hi Repsol69,
Sorry to hear about this! Do you plan on having your dealer look in this? If so, we're happy to assist with this process. Please send us a private message if you decide to got this route.
Lydia
ATXRamSport
I'm also experiencing the clicking sound in the driver seat. It only happens periodically, and usually when accelerating. But sometimes it goes days without occurring.
Add that to the interior deceleration vibration that occurs when between 15-0 mph that sounds like it's coming from the center console/center of the truck.
2017 Ram Sport 25K miles, so not just a 5th gen Ram issue.
