- Feb 24, 2018
- Solutions
- 1
- Location
- Central Pennsylvania
Very confused by this comment. It was said that a 3.92 in 8th is the same as a 3.21 in 7th. This really only works here.To me, as long as you are driving a speed which the transmission would use 2 - 7 for, there should be no difference between the two trucks.
1 thru 6 are direct drive...7 and 8 overdrive.
3.92 will produce the torque effect more than 3.21 in all gears.
I have a HD with 6.4l and 3.73. 2nd to first is a huge jump, and with 4.10 I could hold second longer than 3.73 instead of having that annoying downshift.
So, here in PA we have some very steep roads. 3.92 in second will have more power than a 3.21 in 2nd. And that is the area that the tow ratings come into play. That 3100 extra lbsthe 3.92 is rated for...that is where it get that extra rating.
Also, 3.92 will help with engine braking going down the hill. Hence the 3100lb more GCWR.
Once again...the only non opinion reason to get the 3.92 over the 3.21 is the 3100lb extra rating.
But, then, we also know how guys feel about the rating.
So, it is opinion and your own opinion is all that matters.
