Willwork4truck
Agree with above, my caveat would be to “get (slightly) more truck than you need”, not crazy more but set it up so you have “margin”...There's kind of two different train of thought's that people have been taking in this thread. Either someone says you need a 3.92 to tow anything at all, or someone says the 3.21 has the same transmission so it must be able to tow the full 12k instead of 8.
Neither of those are correct. This is not as black and white as that, in either extreme. I'm in the middle defending both sides of the argument as long as it's within the rated capability of the truck.
Here's what I'm saying. If your truck is rated to tow 8k, then you'll be fine towing 8k or less. If your truck is rated to tow 12k, then you'll be fine towing 12k or less. It's up to YOU to choose the correct truck for YOUR application, and is NOT the forum's responsibility to guide you on what's "OK" when it comes to overloading a truck and using it beyond it's intended capability. That part to me IS pretty black and white. If you know what you need for a weight rating, get the right truck. If you don't know what you need for a weight rating, and buy a truck that ends up not being capable enough for what you want to do, you either need to compromise on what you're trying to tow, or get a more capable truck. It really is that simple.
(The "YOU"'s there are collective you's, not personal, fyi)
A truck “can” tow or carry more weight on occasion however it (and you, and people behind you) may be a lot happier had you made a different choice. Usually that “different choice” will cost you more than if not made, but there’s other factors that come into play as well.
