Gman
I wouldn't worry about it.
I recently purchased a crewcab 4x4 hemi with the 3.21. If I am going to be towing an ultra-lite or lite travel trailer between 4500 and 7000 lbs., do I need to worry either way since it is under the 8000 limit for the 3.21?
No, I dont think you will have an issue. Lock out 8th gear perhaps. Read some of the towing threads for more up to date info, I don’t tow anymore.I recently purchased a crewcab 4x4 hemi with the 3.21. If I am going to be towing an ultra-lite or lite travel trailer between 4500 and 7000 lbs., do I need to worry either way since it is under the 8000 limit for the 3.21?
Not getting anything near that on mine...
Just took a trip from FL to WI
75mph and cruise control, 87 octane
15 mpg was average
14 mpg was worst tank
16 mpg was best tank
Have to add up the info for the ride back..
Not a bad chouce. If I were to tow more than an ultralight rv less than 22’, a bass boat/jet ski I’d have taken the 3.92 gears. As it is, the 3.21’s do fine in hills. If I wete back living in the Rockies, then 3.92.I went with 3.92 for the towing and not knowing were I will get stationed at next. Could be flat land or hills who knows.
Roughly 1500 to 1600... 19.5mpg flat cruising speed. 80mph 1900rpm and 18.5mpgCan anyone post what the rpms are at 70mph with 3.21 and 3.92? I have a Laramie with 3.92 and get around 2000 or 2100 rpms at 70mph. Curious to hear what rpms the 3.21 is at 70mph!
With 8 spd transmission
3.92 or 3.21?I’m exactly 2000 rpm’s at 70
3.92 or 3.21?Roughly 1500 to 1600... 19.5mpg flat cruising speed. 80mph 1900rpm and 18.5mpg
3.92 is in his signature.3.92 or 3.21?
3.923.92 or 3.21?
Do you have bigger tires? I have stock 20 inch rims and tires and I'm getting right around 2000 rpms at 70mph3.92 is in his signature.
I think you meant to direct that response to @Firebird.Do you have bigger tires? I have stock 20 inch rims and tires and I'm getting right around 2000 rpms at 70mph
