Rampat
Hey guys. For those that have this lift, how is the ride compared to stock?
jwiley386 - I had my lift installed. I am just curious to see if the 24" you have at the front is the way it should be with the addition of the spacer? Mine is currently in the shop and as soon as I get it back I will check. Is there any other way to tell if I have the spacer? Thank you for this as I had no idea it might not be right. You are absolutely correct MOPAR hasn't put anything out about this.
I concur. Very nice ride.Extremly well, no exaggeration.. But I would expect nothing less from Fox Shocks.. They are tier 1.
Where's the best place to buy the updated lift? I checked with my dealer and they are clueless.
I had mine installed on Tuesday. When I rev the engine to hear it I get quite a bit of crackle and even backfire sound. Does yours sound the same?Yes it is the newly released one and when I first had it done I took it on a 500 mile run. I really like it now do I think it’s worth the money, well I feel the same can be accomplished for much MUCH less. No video as I suck at actually remembering to do anything like that. My family’s home today so I’ll ask my daughters to remind me.
Hi guys,
I was wondering if someone would be willing to measure there truck from the ground to the gps antenna and let me know what the height is? The reason I’m asking is because I would really like to add the Mopar lift and 285/65R20 tires but I live in a condo with an underground parked and I’m not sure if it would fight height wise. My parkade is 6 feet 8 inches.
Thank you for the help all
I think it would be extremely close.
My Mopar lift and tires are getting installed today. I will measure it this afternoon.Hi guys,
Wonderful thank youMy Mopar lift and tires are getting installed today. I will measure it this afternoon.
Looks like you will need to go with smaller tires to make it work. I have 6' 9" to the top of the fin with the 2" mopar lift and 33" tires. The tires you are looking at are approx. 1 1/2" taller, so you will be adding 3/4" +/-.Hi guys,
Awesome thank you so much for measuring your truck. Do you mind posting a picture?Looks like you will need to go with smaller tires to make it work. I have 6' 9" to the top of the fin with the 2" mopar lift and 33" tires. The tires you are looking at are approx. 1 1/2" taller, so you will be adding 3/4" +/-.
