RoosterWyo
- May 23, 2019
I've been running both together for several months. If you make all your Vehicle setting before installing the Pulsar, everything works. The Live Settings assigned to cruise buttons work fine also (Line Lock, Fast Idle, or whatever you want to assign). The Live Settings menus aren't usable but, apart from the 0-60 timer, there's nothing I need in the menus. It'll be nice when it's fixed but I don't regret the purchase as is. It's field upgradable so I'll flash it when a fix comes out.
Thanks for the info. I wasn't aware that line lock, etc... works. Are you able to switch between performance, tow, etc...? If so, are there any special steps to prevent problems?
~Rooster
2019 Ram 1500 Longhorn
