bneutzler
I have the 19' Ram 1500 quad cab 5.7L with 3.21 gears. 7,500 miles. No admins or aftermarket parts. Had first oil change at 5200 miles. This morning I went out to move the truck and it came on but immediately started sputtering and idling terribly. The rpm would go up to a normal startup rpm and then go way down to almost dying, then fluctuated greatly up and down for about 10 seconds. It finally leveled out. I turned the truck off and then turned it back on and it was fine. Never had this happen before. no check engine lights are on or came on. I am not sure if I can take it in and have it looked at without a check engine light. This day in age, dealers and mechanics generally can't find jack without a check engine code telling them where to look. what do y'all think ?
