Ramit392
I have the same issue and have done a full reboot 3 times with no luck in fixing it. I know have a service stability control light on and can't get rid of it. Did I get a lemon or WTF gives.
I texted Z automotive with no response. Does any one have any ideas for me. So far not very please with this unit.
Sent from my CLT-L04 using Tapatalk
Go to your Unconnect settings and then select aps then select 360 Cams option and see if that does not resolve for you. When you enter your cams by double tapping mute button do not select the back up cam. Just select all cams but the back up cam and no issues will occur. If you forget and select back up Cam and it will not work go back in unconnect ap and select the flashing 360 cam option to get back up cam to work again..
