Kungfubhuda
 - Jan 25, 2019
All good info, but I thought 3.92 was supposed to get worse mpg?
			This is incorrect. eTorque plays a role in shift smoothness and efficiency. It recaptures energy via regen by slowing down the engine speed on upshifts, and speeds up the engine more efficiently than using fuel for downshifts. It also can enable to MDS to operate a bit more when the engine is on the cusp of needing more power when in 4 cylinder mode.No it does not and the terrain here is southeastern Pa is constantly rolling hills not much flat around here AND eTorque is shut down when in Tow/Haul
All you rock stars getting great mileage, how fast are you driving? Cruise control? I can be in 8th gear at 1600 to 1800 RPM going 75 getting a sexy 15MPG on the highway. How you doing it?
I have a similar driving style. 5 over posted, try to get eco to turn on, etc... I am probably averaging about 15 or so. My Fuelly average is less because of some hauling I did on my last 2 tanks. My gauge is showing 15.3 at the moment so I am sure that will hand calculate a bit less when I got to fuel it up.I have about 1600 miles on my Longhorn with ORG, 3.21 and no aftermarket lift or wheels or tires. I have yet to hit 15MPG average, and I absolutely baby the throttle. I have only engaged 4WAuto twice for very short periods of time in heavy storms. I drive about a 50/50 mix of city/highway and have only remote started it once. I try my hardest to be easy on the gas, go no more than ~5 MPH over the speed limit, I try to get the ECO light to come on as much as possible and I cruise with no gas downhill, still no 15 MPG.
I am hoping that it gets better. I'd be very happy with 17 MPG average.
I'm just about to hit 500 miles on my stock Limited 4x4, 6'4 bed, 3.21 gears. Best I'm seeing right now is around 14.2 mpg and that's driving it smooth and easy. I hit very few stop lights during my 17 mile route back and forth each way to work. Avg speed on the 2 lane section of state hwy is 55mph for 13 miles. Then I hit 70mph on the 4 lane interstate for about 4 miles. I'm currently quite a ways off from my window sticker for my build that shows a combined mpg at 17. Hopefully it gets slightly better but I don't expect anything dramatic. I absolutely love this truck despite the mpg. I'm not shocked as I knew it was a far cry in mpg from the compact 4cyl truck I was in. But oh this Limited is incredible! I'll never go back to a compact!
