2019 RAM 1500 MOD INSTALL/REVIEW VIDEOS
DonsRam19
South Carolina
Here's my YouTube channel for videos of aftermarket parts and other vehicle accessory videos please Subscribe if you would like more videos added weekly thank you!
Here's a video of the aFe magnum cold air intake
Here's a install video for you guys that want you install a pulsar and have a visual reference.
Don I see you have the 14” magnaflow. Did you install yourself? Any videos? Is it just the muffler or did you do a catback? What are your thoughts?
I got it installed at anyor tire Mart(a local shop) I have a video of the sound right after the Install
Do you respond when the viewers ask you questions ?
@DonsRam19 thanks for the vid. Is that just the muffler? Not the full catback? Are you happy with it or wish you had more/different sound?
Just the muffler. I'm happy with it eventually I may cut out the resonators to make it a little louder though.
Are you talking about both resonators, or just one ?
Two. The ones behind the exhaust tips.
There are actually four resonators, two on each side, front and rear. I’ve heard many people say the resonator delete doesn’t change the sound too noticeably from the outside. The biggest difference is the “drone” it eliminates because it is designed to filter out the low end frequencies. I believe the main reason most people delete them is because they have weep holes which allow air to escape and it causes a weird sound when mds activates. So some people delete them, others weld the weep holes (which can lead to rusting at the weld joints) and others just do a complete catback...which eliminates the resonators and gives you larger and straighter pipes (most of the time). That’s what “I think”. I haven’t heard the difference in person between resonators in vs out
I was told NOT to do a resonator delete as it is the resonators that save you from the drone.
Yes, resonators are what help the most on drone for our trucks with a stock or aftermarket muffler. To clarify, we only have 3 resonators. 1 pre muffler & 2 post muffler. I would take a educated assumption that the front of muffler resonator does the most work.
If you delete muffler to straight pipe probably still not to bad. Remove rear resonators will notice drone. Remove front resonator with that combo and it’s drone city.
Sorry Don, thank you for the post(s) and hard work not trying to hack your thread. Just trying to help clarify
(y)
(y)
Well I'm just gonna stick with my set up cause I don't want drone! Thanks everyone.
