Air Suspension payload?
Daniel
Quebec/Canada
If the trucks are spec'd exactly the same, there should be a 33lb reduction in payload on the truck with air suspension. (Due to the difference in weight between the truck with regular suspension and the truck with the 4 Corner Air Suspension.)
No the opposite you gain 70 pound of payload since air suspension are less heavy then coil spring
Daniel
Quebec/Canada
and by the way my payload sticker is 1857 tow load 11400 ,Big horn quad cab level 2, 4 x 4, air sus, 3.92 with e lock diff , no bed liner regular front bench, no sun roof no side steps no ber liner
riccnick
Southwest Florida
There's no way its lighter. Compressor, tanks, lines, etc, it's gotta be heavier than a steel spring truck that doens't have all that. Even if the strut assemblies were lighter than the comparable shock and spring assemblies, non-air trucks don't have the other stuff
Daniel
Quebec/Canada
I compared them at the dealer and it is lighter
Zeronet
Florida and West Virginia
I got the 33lbs for the air suspension directly from Rams 2019 1500 fleet optional equipment weight spreadsheet. I don’t have a link but here’s a screen shot. It’s actualy 34lbs, my mistake.
