Flowmaster...Borla...Magnaflow???
Rambro23
I went with the #19430 Magnaflow and it's perfect to me! Just the right amount of deep, thundering tone i wanted.
Nails
San Antonio
Flowmaster bolt on is almost identical to the MF b2 bolt on. Weight should be just about the same
securityguy
North Florida
If you go to Flowmasters website, I believe they list the weight of their mufflers on there.
RichT
22lbs is the Flow fx weight on amazon. Will be interesting to see what the stock comes in at.
securityguy
North Florida
Personally, I'd stick with what's proven and known...like Borla, Magnaflow and Flowmaster. Several high performance shops told me that the Magnaflow is a far better product, quality wise, then the Flowmaster and they sell all three. The Borla is the top of the line but you don't see what's underneath the truck anyway so Borla/Magnaflow is really a toss-up based on what you're looking for.
Joeyp
Jersey Shore
The B2 fab is a fine unit. I’ve had mine for several months now, could not be happier with it. It is very price competitive, install is easy, cost me $40, and the sound is not over the top.
IMO, Those paying for the cat back system, are tossing a perfectly good factory cat back in the trash. The seasoned, experienced guy, that installed my B2, was impressed with the factory exhaust piping.
Everyone has their reasons for modding, if that includes cat back money, so be it. Did not fit my budget.
Did you get the 18in?
porkie
Be prepared to wait. Ordered mine 1/25 and it’s finally being delivered this Wednesday. They took the transaction at the date of the order and not when shipped since it’s coming directly from Magnaflow.
Joeyp
Jersey Shore
Thanks...I'll be sure to follow up. Magnaflow has in stock so hopefully it wont take too long...
Joeyp
Jersey Shore
Its shipping out today :)
JayMann
interested in this B2 line... it's a bolt on ?? no need to cut or weld anything, right?
Kntoys
You do have to cut on one end to remove. Then it's bolt on.
I removed the right side, about 3 ft from the tip is a clamp and that side seperates. After that, worked it fwd and out....not too bad. Have still figure out the left tip alignment ugh. Sounds bad azz though. Def old school and not if you want to wake the neighbors
Ram1984
I have a question about the B2 muffler. Are you guys using any hi temp rtv silicone or the copper gasket maker for slip joint exhaust connections or just reusing factory flange gasket before muffler and just the clamp at back of muffler? I always had my muffler welded on previous trucks,,and don’t want any exhaust leaks. Thanks for the info!!
