Headlight bulb replacement - Bighorn
kingkasc
Don’t do anything else but headlightrevolution.com. Bulbs are super bright and looks amazing. They are brighter than the stock RAM LED headlights
Did you need the anti flicker for the hikari fog lights? Thanks
vvgrovervv
be warned with cheaper LEDs. there have been more a than a few electrical fires from using inferior products. Stay away from the Hikari ones on amazon. You can use if you want but its your truck and no warranty when you fry a circuit. If you want the best check out this site: https://www.theretrofitsource.com
they are the market gurus for headlight upgrades and they dont deal in cheap ****, only quality parts. They also have facebook page.
kingkasc
Has anyone bought the extended gromet for the seal? Did it do the job? Thanks
Mason1217
Michigan
You cant even select the year 2019 on their site and ram isn’t a brand, you still have to pick dodge. Maybe they should get with the times lol.
vvgrovervv
website my not be the most up to date but they have the best stuff
Mason1217
Michigan
Have you used them for a 2019 ram? I was interested in comparing to headlight revolution but it seems like they don’t have a single item for 2019 rams yet?
kingkasc
Which brand? I ordered headlight rev low beams and hitari fog lights from amazon.
Mason1217
Michigan
I was wondering if he found bulbs from the site he recommended because I don’t see anything for 2019’s. Was wondering how the site he talked about comapred to headlight rev.
SB89
How did you install your low beams? I was doing the high beams yesterday and that was difficult even with the filter box out completely.
I also did the fog lights, reverse lights and cargo bed lights already. Saved the low beams for last since they seemed the hardest.
This is where I'm at with my truck too.
I just bought LASFIT LED's for the tail lights and cargo lights (https://www.amazon.com/gp/product/B077PQWQR2/ref=ppx_yo_dt_b_asin_title_o00_s00?ie=UTF8&psc=1) but have been holding off on the LED headlights because I've heard about all the headaches with installation.
For anyone who has installed the Supernova V.4 from Headlight Revolution (https://headlightrevolution.com/2019-ram-low-beam-led-headlight-bulbs-supernova-v-4/) is it easier to do as they did in the video from above by removing the ground wiring on driver side and filter box on passenger side - or is it easier to come in from below by removing the wheel well liners? I'm dreading replacing these headlights but it's high on my priority list.
Granite5thgen
Upstate NY
Those are definitely a huge upgrade, but the stock LEDs have a very good width especially with the fogs on and have full illumination with no dark spots really. I dont think these are quite at that level but it's a huge improvement over stock
YoAdrian
Moderator
RI, USA.
First to the OP (a while back) @deanfx be advised the supernova v4s have fans on them, since you mentioned you did not want that. The fans are not too noisy, you can only hear them when the engine is not running... BUT only time will tell if they stand the tests of time and the elements.
...but have been holding off on the LED headlights because I've heard about all the headaches with installation.
First, don’t do any of this if you aren’t prepared for at least a FEW headaches. ;-). Nothing insurmountable though, just be careful and bring a patient can-do attitude and all will work out.
I installed Supernova v4 lows and highs, and found it to be worth the time to open the front of the wheel well liner for another angle to get my hand in there. The site’s videos were very informative but didn’t do justice to the time and trial-and-error required to fit everything inside the dust covered compartment. Eventually got it all in there though.
FYI these lights are almost too bright, blinding oncoming traffic unless you adjust them downward. Great in the boonies (like where I grew up) but potentially problematic in higher trafic areas. My 2 cents, good luck with the upgrades.
kingkasc
Mine come in the mail today. How do I go about on pointing them down? I def don’t want to be blinding ppl here in detroit
JDiMassa8
Ohio
I don’t know man. My buddy has the led upgrade on his and in his opinion and mine we agreed that these headlight revolutions were brighter. Now I don’t know about high beams since I didn’t get those. The dogs that I got as well I can use as the headlights just because their extremely bright as well. But now that I tinted my headlights....it’s a different story. Lol
Granite5thgen
Upstate NY
Looks sharp I like the black. I cant wait to debadge and dechrome the few badges that stay
YoAdrian
Moderator
RI, USA.
There’s a faq post around here somewhere on adjusting headlights... get on level ground with a flat surface to shine onto (like a garage door), pop the hood, use a long hex driver (6mm?) straight down into these little funnel looking tubes behind the lights to dial each one higher/lower. Lots more measuring if you want to be precise, but I just marked where they were originally and guessed how much lower I needed to go to not hit oncoming driver eyes. I had to go full deflection down, still illuminates the roadway fine. YMMV.
If I recall correctly to aim the lights down, one side was CW and the other was CCW... but just watch while you slowly turn to confirm this as I’m not 100% sure and this differs from other reports here. Would love to hear whether you confirm the direction. Don’t over adjust them or you might hurt/strip the threads somehow. Lemme search hang on... ok link HERE and I’ll go outside and shoot a pic. Ok pics attached, good luck.
YoAdrian
Moderator
RI, USA.
Let me try to share a video with audio of the headlight fan noise. Quite audible actually with the engine off. For those of you with Supernova v4s are they that loud for you too?
SB89
I've seen some people have no issues with fan noise and others like this. How is the noise compared to say....a cell phone vibrating? Can you still hear it inside the cab while driving?
