OK well I guess I owe you all a mini-review!
The part arrived Friday afternoon, so I popped it into the truck as soon as I got home. Pairing was a bit finicky, and the instructions are pure ****e. However, it seemed to connect at first, then it didn't, then it did. At one point when it was connected, I was able to go to the update website and it said there was an updated firmware--this is absolutely critical. After installing the firmware, the unit was more stable and seemed to work the way you would expect.
So today I drove around with it, about 7-8 times in and out of the car. All but once my phone connected and the Carplay began automatically. I would say it takes 15-20 seconds after you turn the car on for your phone to connect. The experience has been generally good, but not flawless.
Positives:
- When it works, which has been 90% of the time, it's really neat. Phone is tucked away in my pocket and I have full Carplay access
Negatives/unknowns:
- Remote start might be an issue. The one time it didn't connect for me was when I used remote start. I unplugged the unit from the USB port and reconnected it and my phone connected to it fine after that
- My backup camera has been iffy while the unit is plugged in. Sometimes it doesn't come up automatically when going into reverse--but other times it works just fine so I'm not sure what's going on. The screen icon works just fine
- One time, I shut the truck off and it restarted itself immediately. That was very weird. Did I mash the start button twice by accident, or was something else going on? I don't know.
- There is a very slight lag when using the Carplay interfece vs. hard wired. However, it's more than acceptable.
- I'm not sure how wireless Carplay is supposed to work, but this unit seems to connect to your phone via both bluetooth & wifi. However, niether one actually shows that they are connected from the phone side once you are actually using the unit.
- The center console USB port does not work for Carplay. It looks like you must use either 1/2 that are under the screen, or #3 in the back seat if you have that option.
So the bottom line is that it's new/experimental, but if it works for me the way it did today I would be very happy. I have not spent enough time in the truck to experience all of the bugs I'm sure, but if I've seen the worst of it then this is a great improvement from stock
Tips: disconnect/forget the Uconnect in the truck and then update the firmware immediately. I am using an iPhone 11 on iOS 13.4
