wind noise from the sunroof
Scooter01
I have been experiencing wind noise like others here, both from the window area and the sunroof. I am thinking of installing one of these deflectors:
https://www.autoanything.com/deflectors/avs-windflector
for the sunroof to see if this helps, has any one else done this yet? And if you did did it help cut the wind noise down?
Any suggestions would be welcomed thanks
I experience the same issue. Purchased my ram 1 month ago and started noticing the sound about a week ago. I would think the mesh air deflector would interfere with the part you are suggesting
I also had the issue with the panoramic sunroof it would be a whistle sound from the front passenger area of the sunroof glass. Took it to the dealership and they adjusted the glass and it fixed the sound right away.
I have taken my truck to the dealer once already with this issue. They claimed the sunroof was out of alignment. The service manager verified the noise when on a ride with me. He drove a new one on the lot and did not experience this issue. After keeping my truck for three days they said it was fixed. It is not. Same issue still going on. I have second appointment in a week to try again.
Mine also whistles when at high speeds or in a strong head wind. Can push up and push down on the glass with relative ease. Seems it should be tighter than it is.
Hi cajunscott,
We are sorry to hear that you have this concern with the sunroof in your new Ram. If you are in need of additional assistance while your Ram is in service for this, please don't hesitate to send us a private message.
Darlene
Ram Social Care Specialist
Hi cajunscott,
Darlene
what are you guys doing about the gas tank and gauges being off?
Well I brought my truck back in for a second try at fixing the air noise in the sunroof. They changed the weather strip around the entire roof and re-adjusted the glass a little more and it seems to have solved the problem. The factory strip was crushed (Not sure why) and this was causing the noise. Hope this solves the issue for good. Other than this one item I love the truck!!
Same issue with wind noise here. It seemed to only start when the weather got colder around here though.
Between my Bluetooth media static (no resolution by the dealer yet) and this, I'm just bundling up the issues with this truck so it only needs to go in once to get fixed.
Well I think the cold weather is the issue. After the second trip and replacement of the weather strip the noise had reduced greatly. It happened to be warm that day. Since the cold weather has moved back in the noise has come back. I did notice that the whistling sound I here is not from the sunroof. It actually comes from the noise canceling speakers in the roof. High speed or strong head wind sets it off. I assume this is happening because of the high wind noise coming from the sunroof. Poor design!!!
Same issue with the pano sunroof. Gap between front of glass and weather strip seal. Service tech tried to re-calibrate but did not fix. I can stop noise by helping/pushing the glass forward when it finishes closing but it will not close tightly on it's own. I would rather not have the headliner removed to adjust the track if that's not the issue.
I don't think many pano owners have same issue because there aren't many complaints on the forum. I am hoping another try at re-calibration will fix so I am looking for the procedure instructions to do myself.
If anyone has had same issues and fix, please reply.
My pano sunroof has en excessive amount of wind noise. I have an appointment with the dealer next week. When I called the girl on the phone said someone else just made an appointment for the same thing. I'll cross my fingers they can fix it. I wonder if it's just a calibration issue?
So I think this guy has nailed my problem with the noise. Here I am thinking it's the sunroof. I here this same noise at high speeds or strong head winds. I also though it was the noise cancelling speakers but this makes more since.
I have wind noise from my Pano roof. Also when I was driving last week in a very strong crosswind I got a very load continuous whistle from the driver side window. If I just barely crack the window, not even enough to have it come out of the stripping, the whistle will stop.
I have an appointment tomorrow to address these...along with the suspension being stuck in Aeromode, the Sirius channels not changing, 2 recalls. I haven't owned a Ram truck for about 20years...I'm beginning to know why now!
Update: Dealer has my truck 12 days and counting now. So far, they removed the pano, which required removal of the headliner and windshield. They said the front corners of the seal were crushed and were certain this was the problem. They ordered new parts and reinstalled pano, windshield and headliner. Then they test drove and STILL GETTING WIND NOISE!!!! So they're still working to fix it! I'm afraid that installation must be tricky without damaging seals. I don't think they want to take out the pano again so I suspect the next step might be a shade tree patch job. I'm very concerned now. Going on 2 weeks since I dropped it off.
No brand is immune to bugs but I certainly understand the frustration. I'm in a 2019 chevy 1500 rental now and it's a pile O'crap! There's not enough room here to list all the terrible things about it. I'm not a brand snob either. If another brand made a better truck, I would have bought it.
Hello forum, New Ram 1500 Limited owner here. I wish I was posting just to celebrate. I am experiencing the same. Test drove panoramic roof model and was literally stunned by how quiet the ride was. Found the specific build out we wanted at a different dealership and picked it up this past Saturday. As soon as we left the dealership and got on the highway we realized there was wind noise from the front of the sunroof which is intolerable. Made the 3 hours drive home truly miserable. All smells from outside in, couldn't hear each other to talk. Like having a window open on the highway. Nuts. Dealership was then closed for the weekend and we were stuck driving the factory defect model several hundred miles home. Definitely disappointed with that aspect of the purchase thus far. We love this truck other than that. The dealer picked up the vehicle today and is assessing. Truly concerned if there is a fix. Is that fix going to be permanent? Will the quiet cab I fell in love with ever happen if they try to fix it? Along with the sunroof noise, there is a quiet electrical whine from rear speakers at idle, and some intermittent clicking from the small microphone looking ports on the roof in the rear. Back seat passengers on a 20 min drive said it was intolerable to ride back there. We are really nervous about this decision.
The truck drives amazing and we really hoped this to be our favorite vehicle ever to tow our new travel trailer. Is there a reliable fix? If so, what is that fix (new weather strip, slide glass forward)? Is the speaker whine bad ground to amp? Is my active noise canceling faulty (speaker/microphone clicking)? The dealer has offered us two choices: (1) They will cancel the purchase and drive our trade in back to us (3 hour drive) or (2) they will fix it (they say it can be fixed but also claim they have never ever heard of a sunroof issue with a Ram 1500 which I find unbelievable, in which case how do they know they can fix it if true?). They refuse to order a new one for us saying "Well if we order a new one for you it could just happen again so let's just fix this one". I feel like for a very expensive luxury truck we should get a non-defective unit to go home with, not one that they surely knew was defective (greasy fingerprints and hand prints all over the fabric around the sunroof and on the sunroof where someone clearly tried to mess with it (but with travel plans that would cancel a bunch of plans so not first choice from a timing/logistics standpoint but worth it if the alternative is to be stuck with a permanently defective unit). Our challenge is that this particular color/interior/build out is EXACTLY what we want and apparently the only one in the country. They offered to get us one off another lot but say it doesn't exist. So, we could get our car back and order one just as we want it new from a different dealer or keep this one and hope they actually fix it which makes us very nervous that we'll be stuck with an ongoing, never ending saga. Please, Ram/community help? We have to let the dealer know what we want to do tomorrow, Tuesday 03/19/19. Thanks so much in advance!
