Where on the window sticker does it tell you the size of the bed?
The latest version of the Monroney stickers do not have it. You need to simply look at the 6th digit of the VIN. If there's an "F" it is the 6'-4" bed.
The 6th digit on my VIN is an "F" and I have the 5'-7" bed. I don't think this is a reliable indicator unless something has changed along the way.
Here...since both FCA and the consumer (and every other brand) are equally responsible to give accurate info.
VIN decoder
F and the 6th position definitely isn't it.
And the 7th is the designated but is different for each trim. So F would only be for a Bighorn crew cab shortbed.
It is a little more in depth than just the configuration I believe
Sorry it took so long to get this info, but work expected me to perform my job today.
Quad only has a long bed. 7th digit is B,C,D, or E
Crew short is F,G,H,J,K or L
Crew long is M,N,P,R,S,or T
See the VIN decoder for details
Edit: the link is the red letters.
The 7th digit will give you cab and bed size, each letter makes it specific to trim also.
I was getting worried. Havent heard back from anyone in the other post...so I thought, wow people probably think I am crazy lol...which may not be wrong for other reasons lol.
Turns out there's a vin decoding sheet FCA put out.
Letters 5-7 on your VIN need to be RFR for it to be a 6'4" bed in a crew cab
Looking at mine 5 thru 7 are RFP and its a 6'4" bed.
RFM on my Bighorn Crew Cab
Here is a VIN (mine) breakdown for your viewing pleasure.
6th character denotes bed length.
Sorry for all the dashes, but the site kept removing the blank spaces.
1C6SRFPT5KNxxxxxx
1|||||||||||----- FCA
-C||||||||||----- USA
--6|||||||||----- TRUCK
---S||||||||----- Hydraulic Brakes/GVWR=7001-8000 Pounds
----R|||||||----- Crew Cab
-----F||||||----- Long Bed
------P|||||----- Limited
-------T||||----- 5.7L V8 GAS
--------5|||----- Check Digit
---------K||----- Model Year: K=2019
----------N|----- Assembly Plant: N=Sterling Heights
-----------xxxxxx Assembly Plant Sequence Number
Steve
The 6th digit denotes 4x4 or 4x2. 4x2 is E and 4x4 is F.
The reason 5 thru 7 position is different on each of these quotes is because it goes by trim.
I noticed the one quote says about the vin decoder.
So 5th will be R on all, 6th will be E or F and 7th will be different each time for cab size, bedsize, and trim.
Any idea what S for the 7th is?
