Wheel spacers?
KyleD
Hey guys anyone with issues on 1.5” wheel spacers on stock rims for 2020 ram laramie. I am looking to get some but i want to know if i should or not? Please help
Spend the money for the Bora spacers and don't worry about it. Also something to keep in mind. The front track with is 1/2" wider than the rear. So if you want front and rear wheels the same, need 1/4" smaller spacers on the front
jl13
boyle heights, CA
I also went with bora, 1.5"
I only have done city and highway. No off road for me so far.
Got them last june
31RamIt
I have a set of 1.5" KSP Spacers sitting in my garage. Anyone use them? Reviews seemed good, and cheaper than Bora
moparleo51
i have a set on my laramie ram with oem rebel wheels and they work just fine,
Malodave
Rindge NH
I have 1.75" on the Front Axle and 2" on the Rear Axle. Stock Wildpeaks.
Malodave
NJC1684
North Dakota
1.5f/1.75r
Ex_dutch
I talked to”my” parts guy last week. I want 1.5” spacers, pretty much settled on Bora but he just got Synergy spacers himself for his Jeep.
I like the std Laramie wheels and I like a standard look “but there’s something about it and I can’t put my finger on it“. They are supposed to arrive this week, appointment to put them on on Friday. I’m expecting a rubbing issue with the front Mopar mud flaps, probably time for the “ice buckets” to go. I’ll post an update with pictures when done.
Seems they’re dirt cheap, hope they’re ok.
Ex_dutch
Appears they didn’t get there in time - sat there for nothing for half an hour. Called the dealer to see what’s up last week, found out they only got 2 of them. Thursday is D-day. Looks like the red anodized color should show just enough to notice that “something” is different. I may have to break down and wash the truck so I can take a few pictures.
Anyone experience with Synergy spacers on their RAM?
Ex_dutch
Today was the day. Dealer ended up ordering KSP spacers, 4th appointment (first time they hadn't arrived, 2nd time only 2, 3rd time wrong thread).
I think (j/k) they rub (see first pic, LOL). It's bad. Took my Mopar mudflaps off for now. Backed in and out of the driveway and I'm OK. Looks like I need to get rid of the ice buckets. Not sure yet if I have to trim the original plastic part behind the Mopar mudflap (where the plastic pop-thingy) goes through. There's 1 on the bottom too, so I need to get 2 for each side.
Geddyflea
Your truck looks great! I've got 1.5" KSP's on my Rebel. I've had them on for about 8 months with no problems.
Ex_dutch
Thanks! Rubbing is really horrible with the mud flaps, but not completely unexpected. It‘ll just take some serious trimming to make them work (more than I thought).
Dealer didn’t use loctite as per KSP. When I asked they said to get torque checked after 500 mls, that’s all.
jl13
boyle heights, CA
Same instructions on bora as well. No loctite, just retorque.
I am getting close to 5k miles with the spacers Plan on checking and re torque if necessary then
Ex_dutch
Finally got the mud flaps back on the truck. It took quite a bit of butchering, but no more rubbing…
Julio13
I just installed 1.5” ksp spacers on my big horn what did you torque it to?
Ex_dutch
To be honest, I don’t know.
Thanks this board, I just knew enough to ask a few questions and find out the dealer didn’t use locktite and to retorque at 500 mls.
So when I came in for retorque, someone took a torque wrench and started to torque the wheels. I’m like nope, could have done that myself. You’re gonna take off my wheels and check the torque on the spacers.
I guess that’s a lesson learned. I have the oil change and tire rotation plan, but it seems I’m going to have to provide “instructions” moving forward since not every mechanic is familiar with the concept of spacers.
Did the dealer install the spacers? If not, then they have no responsibility to verify torque on them, and could charge for the service
