Wheel and Tire Overview
Fellow Canadian you can use OEM 18 inch wheels, I previously did. Sensors will pick up by themselves.
Would you happen to know the part # for the OEM 18" steels? In a similar boat, looking to get some steel wheels for the winter
I have a 2020 Limited ORP/ORG on order with 20" tires and wheels. will be swapping for after market set. Let me know if anyone is interested in factory 20" takeoffs
I just got 20x9 fuel contra D644 added with 305/55/R20 Nitto Ridge Grappler with 0 offset on stock height 2019 laramie 4x4 with no rubbing. it's close though hit a bump too hard at full lock I may have some rub.
Posting because I was unable to find this information, forgive me if I missed it.
2019 Ram 1500 Bighorn. Stock suspension. No lift/level. Stock 18" rims. Will fit 295/70R18 Trail Grapplers. The only rubbing I have experienced is in reverse at full lock, it rubs the plastic on the front of the fender slightly. This plastic is loose and it seems like it could be pulled clear with the addition of 2 small holes and a ziptie.
The Mods have stickied this thread so that users can share their results with aftermarket rim, tires and lifts. Members please share your results and I will add them to this top thread for a comprehensive post.
Note: I am a wheel and tire rookie! If you see an error in my post, or something I need to add, please let me know.
2019 1500 OEM Rim Sizes
OEM Rim Size
OEM Bolt Pattern
OEM Thread Size
OEM Center Bore
OEM Offset
OEM Backspace
18" x 8"
6x139.7mm
M14 x 1.5mm
77.8mm
19.05mm
5.25"
20" x 9"
6x139.7mm
M14 x 1.5mm
77.8mm
19.05mm
5.75"
22" x 9"
6x139.7mm
M14 x 1.5mm
77.8mm
19.05mm
5.75"
2019 1500 OEM Tire Sizes
Tire Size
Tire Diameter
Tire Width
Tire Sidewall
OEM Rim Width
275/65R18
32.1"
10.8"
7"
8"
275/70R18
33.2"
10.8"
7.6"
8"
275/55R20
31.9"
10.8"
6"
9"
285/45r22
32.1"
11.2"
5"
9"
Aftermarket Rim Sizes
Looking for info from members. Rim Size, Offset, Distance it sits past stock, clearance issues?
Aftermarket Tire Sizes
Maximum Tire Size @ OEM Height
Maximum Tire Size - Rebel or Off Road Package @ OEM Height
Maximum Tire Size - Air Ride Equipped @ OEM Height
Maximum Tire Size - Air Ride Equipped (Rebel or Off Road Package) @ OEM Height
Maximum Tire Size with 2" Level
Maximum Tire Size with Mopar 2" Lift
Maximum Tire Size with Rough Country 3.5" Lift
Other Lifts & Sizes
Does this chart mean the stock Rebel wheels also have a +19mm offset?
if that is the case, I just gained a lot more options
Looking into the same tire size 285/60/20 on Limited Rims stock suspension though - no offroad package
Did you have any rubbing with the 285/60/20? Trying to figure out what’s the best tire to go with on a stock suspension with stock rims
do you still have the wheels?
do you still have them
2019 1500 lonestar with ORPand 3.92 with E locker. Just switched from factory 275/55r20 to. Falcon wildpeak A/T 285/65R20 which is 34.6 x 11.2 wide. NO level just factory ORP. Drives great fits great. Had to zip tie front inner fender liners front and back. NO Rub... super happy with ride and fit...
View attachment 68593View attachment 68594View attachment 68595
Do you have any more before and after pics of your truck? Thinking about going with this size after i add 5100s
I installed a set of 275/60/20 cooper discoverer at3 4s on my 2019 bighorn, stock height, stock wheels. It will rub at absolute full turn. Just barely but enough to hear it for sure.
Were you able to modify for the rub?
I have a 2019 laramie with the OEM 22's and 285/45 tires. I Want a bigger sidewall profile. Hoping to squeeze 35 12.5's in there. Anyone else with 22's put bigger tires on? Will this work with 2" wheel spacers? Do I also need the Mopar 2" lift kit or would the Bilstein 5100's I have seen mentioned alot work or would that not be necessary? It looks like I have alot if room in the wheel well.
can you safely place 265/65/18 or 265/70/18 tires on stock 18inch rims?
Anyone know the minimum wheel diameter for the 2019’s?
Almost pulled the trigger on 17x8.5” method NV’s (plenty of 4th gen’s run them) but a quick check behind my stock 18x8 wheels paused that plan: only about 1/8” clearance at calipers(!).
Holy smokes. I'm about to buy some 18 inch wheels with -44 offset. Does offset matter? If so, what is the offset for your wheels?
Go to tirerack or discount tire websites, look up the tires you want, and confirm the minimum rim width required. In this case, the OEM rims are 8" wide.
