What's your favorite low-cost Amazon upgrade?
I wasn't that happy with the center console armrest organization jzer I bought off Amazon. It's still in the truck, but doesn't gold anything in place if you pick up the armrest to get inside. All they had to do was make the divider walls taller to be closer to bottom of armrest when closed.
Agreed. Makes no sense that companies take the time to design these, and then don't spend five minutes testing their usefulness.
Welcome to the forum. Its not a Amazon purchase, but the Hellwig sway bar is a must.
Where are you from, I'm guessing North Carolina?
Whats everyone paying these days for this? On the gen4s they were so much less.
Sent from my SM-G781U1 using Tapatalk
Prices have gone up dramatically over the last few months. Inflation and supply issues. Most people running one, myself included, bought them before the price increase.
Did you by chance do any type of write up on the install? I presume you tapped the existing reverse light wireS somewhere.
There are several threads on it, but I bought the Curt 56584 wiring harness and tapped into that so I didn't mess with the OEM wiring. I soldered extra wires onto the reverse, aux 12V, and ground because I have other things tapped into it. I tend to use JST 2 connectors when possible on these little things because the lights are cheap and tend to die after 2-3 years sitting in the elements. Makes it easy for plug and play.
I should have thought of this given my dog can't get himself up there without scrambling and scratching 🤦‍♂️
The nice thing is these will cover up scratches too, though I would touch any scratches up first
I am...a town called Waxhaw that's effectively a burb of Charlotte. I am an avid Jeep guy, so I'm familiar with the Hellwig's from that perspective. Reduced body roll I assume? I just picked up my truck. It's a 2020 Laramie that's pretty loaded. It had Method wheels and 35" Ridge Grapplers. They were rubbing at full lock, so I hit the liners with the heat gun today and took care of that. To my surprise I discovered it has what must be a lift kit with Fox shocks. I knew it sat slightly higher and was leveled, but I assumed it was a spacer lift. So, nice surprise there.
Thanks!
Like $311 on americantrucks
Yea, they are the only ones holding the price down. Not sure what other vendors are thinking. I have seen some listings over 400.
Crazy, Every now and them a listing will pop in the sell forum for 200-250
I miss one of this listing recently
Nice! I’m pretty positive that’s the 2” mopar lift by Fox! So your factory warranty should remain intact on the suspension
let's see... not exactly low cost but there are alternative options on Amazon, but these are the things I bought from Amazon:
i got my Blue Sea Fuse Block w/ ground (x2), Blue Sea circuit breakers (x2), Blue Sea bus bar. All these have low cost alternative options but I went with Blue Sea since I don't trust cheap Chinese-made key electrical components.
I got my Nilight 5-gang rocker switch system from Amazon. I don't mind the switches go bad since all they do is control the flow of power feed. If they go bad they're not going to cause a fire but 30 minutes of my time to replace.
I also got my HAM radio cat5 extensions and 3.5mm speaker extensions from Amazon too. Those I can do with low-cost MIC since they're inside the cab and not critical to safety.
I also got a Baofeng handheld HAM radio as a backup/ off the truck communication when I spot for my friends. That's a low-cost option from Amazon compared to Yaesu or iCom handheld.
