Obdlink mx+ and security gateway bypass module so I could use alfaobd to add blind spot monitoring.
Do any of the trim lines come with sequential markers or is this an upgrade for every trim level?Sequential LED Side Mirror Marker... https://www.amazon.com/dp/B0B3N47QVW?ref=ppx_pop_mob_ap_share
None of the factory turns are sequentialDo any of the trim lines come with sequential markers or is this an upgrade for every trim level?
I wasn't that happy with the center console armrest organization jzer I bought off Amazon. It's still in the truck, but doesn't gold anything in place if you pick up the armrest to get inside. All they had to do was make the divider walls taller to be closer to bottom of armrest when closed.For a long time I would go out of my way to not order from amazon, no real reason I guess, but recently keep going there more often
Yesterday I just received a center console organizer myself, as well as a center console armrest cover to help protect it when I take my dog on the truck
Also got a light bar amber cover from there, a bed extender about half the cost of the mopar one, and this hitch cover is the cheapest thing I have gotten for my truck.
Yes, mirrors and tail light modules were from the dealer and a wiring harness from jimmy07. I bought the obd2 and sgw bypass on amazon. Those two are well worth the money to me.did you have to replace the mirrors?
I knew this thread would cost me money. Bed mat ordered.Dee Zee heavy duty bed mat (model specific fit). - Even with the factory spray in liner, the rubber liner is a must. It has great grip, you won't need to strap anything down since stuff doesn't move with the rubber mat, also the soft rubber finish of the mat won't damage or scratch stuff like the spray-in liner will, which is like sand paper. If you don't have any liner, this is a great alternative if you don't need heavy side protection.
Top Glovebox Organizer Tray - Adds a bit of organization to the bare space that is the top glovebox.
don't currently carry anything on the top globe box but good share to keep in mindDee Zee heavy duty bed mat (model specific fit). - Even with the factory spray in liner, the rubber liner is a must. It has great grip, you won't need to strap anything down since stuff doesn't move with the rubber mat, also the soft rubber finish of the mat won't damage or scratch stuff like the spray-in liner will, which is like sand paper. If you don't have any liner, this is a great alternative if you don't need heavy side protection.
This is the one I got, it's acceptable, Advertised as having taller walls than others. Went with the full size. The divider by the center back USB gets more movement and is were the walls curved down.I wasn't that happy with the center console armrest organization jzer I bought off Amazon. It's still in the truck, but doesn't gold anything in place if you pick up the armrest to get inside. All they had to do was make the divider walls taller to be closer to bottom of armrest when closed.
Mine came factory but definitely agree with you. Its a well worth upgrade and safety featureYes, mirrors and tail light modules were from the dealer and a wiring harness from jimmy07. I bought the obd2 and sgw bypass on amazon. Those two are well worth the money to me.
Thanks for link. If I get tired of one I have, I will definitely try this oneThis is the one I got, it's acceptable, Advertised as having taller walls than others. Went with the full size. The divider by the center back USB gets more movement and is were the walls curved down.
Probably walls could still be higher
Other options with the non slip mat were cool but I saw a few complains that made stay away from them
I got one of them too. I got mine through the vine program. It was free with the understanding that I'd write an honest review. I gave it 5 stars. Nice tray, not the typical cheap thin plastic.Top Glovebox Organizer Tray - Adds a bit of organization to the bare space that is the top glovebox.
