DonsRam19
Here's a install video for you guys that want you install a pulsar and have a visual reference.
Huh?
The point is, even though our trucks will run on 87, they are designed to run on 89 and higher. Running a lower octane means that the truck will have to compensate for lower than optimal combustion, due to timing adjustments from detecting knock. Running a higher octane allows the engine to use optimal timing curves, and with how advanced engines are nowadays, I wouldn't be surprised if valve timing is adjusted as well. I'm not saying its a "MORE OCTANE, MORE POWER" hard and fast rule, I'm just saying that I'm tired of hearing how octane has no effect in a modern engine. Octane is an anti-knock rating, and detected knock forces the engine to run less efficiently, how are they not related?
(I'm not trying to say this just to you, it's an open discussion)
Someone once told me there is no 89 tank in the ground. It runs a mixture of 87 and 91/93 to achieve the 89 rating. I have no idea if it is factual.
I am an engineer, actually. Octane is strictly a measurement of knock resistance. Engines that use high compression, aggressive timing, and/or forced induction will experience knocking (detonation) with insufficient octane in the fuel. This can severely damage or destroy an engine, which is why modern engines detect detonation and adjust for low octane fuels. Maximum power is achievable only with the recommended octane.
Using a higher octane than recommended has no benefit, you're just paying more at the pump. I'm surprised by the card you found and can only assume they're trying to dispel this persistent myth that higher octane will somehow magically make more power in an engine that was not designed for it. There are no harmful effects to your engine by using higher octane than necessary.
I run 89, usually Arco... I haven’t tried any other grade yet and probably won’t until I get the Pulsar. Using 87 may harm the engine and using 91 is a waste of money. The only thing I’ll do is periodically fill up with Chevron or something like that to help clean out the engine.
Our engines were designed to run on 87 to 89, not 89 and higher. In addition, 89 octane is recommended, not required. There is no mention of any octane higher than 89.Huh?
I have run 87 in my current truck since day 1. I didn't read the owners manual regarding which octane to use because there is no sticker inside the fuel door telling the user which octane to use. So I made the assumption that 87 was good enough. I used 87 octane on my 2017 Rebel for two and a half years, and achieved almost 17 mpg with that truck. My 2020 Laramie is getting about 14.5 mpg after 2600 miles. Now that I know 89 octane is recommended, I'm planning to switch to that and see if my mpg's improve. My take-away from this is it's okay to use 87 octane. But for maximum perfomance and fuel economy you should use 89. Basically summarizing the owners manual. In other words, I haven't done any damage by running 87 octane, but I'll be able to realize my truck's full potential by running 89 octane.
No need to get passive-aggressive about it. I never said anything about pinging, nor have I ever heard anything like that on this truck or my previous one. Of course damage could be happening if you actually are experiencing that.Well if you hear a pinging when using 87 octane under load, is that a "good thing"? I have no idea, but my guess would be "no"; it wouldn't surprise if that was somehow negatively affecting the engine.
