What Direct-fit Muffler should I get?
B2 Fab MF and they are the perfect combo between deep and throaty and quiet when not jumping on it.
The problem is no video is going to capture exactly the way they sound in person, all the little nuances you will notice later.
Also, everyone has different taste to what is loud or quiet. When I was researching the Outlaw, some people thought it was perfect, others too loud and others too quiet. Unfortunately, these are one of those things where you need to go with your gut.
If you don't have to do this DIY, I highly recommend you don't buy the direct fit systems. Instead, spend your money on a custom install with those mufflers. That way you can change them easily and affordably without wasting money on a direct fit you may not be happy with. Most of these mufflers for custom install are just under $100. Custom fit with labor is about $150-$175. The change out a muffler later will be easy along with changing out resonators to tune it the way you like. This is of course assuming you have a good muffler shop.
Checked with a local custom exhaust shop... They encouraged me to look at the Flowmaster Super 40 chambered. I'm thinking the resonance tuning of a chambered muffler is not really necessary on a '19 with all of the stock resonators that I plan to keep. Y'all agree? This muffler is also rated as more aggressive than the FlowFX/Magnaflow, so I'm worried too loud (I tow large camper on longer trips).
They said that if I wanted something straight through and packed, they'd recommend the FlowFX over the Magnaflow because they are essentially the same and FlowFX is 1/2 the price of the equivalent Magnaflow. Does this sound correct?
No one but you can decide, but if it were me and I was going to be towing, I'd go for the tamer exhausts like the B2 MF or equivalent. If you don't, your cabin will always be loud (fine when accelerating, but not for hours on end). You will hate life if you do this (again, that's just me).
Cheers,
That sounds accurate to me. I think if you want a touch quieter, than the FloxFX is the recommended exhaust with the Flowmaster line. They should charge you no more than $275 - $300 out the door for complete install. My RAM dealer recommended a custom install over direct fit because they will be welding instead clamping. After a week or so, decide if you want to tune it a bit by removing and adding resonators.
You can always make it a little quieter or louder without having to replace the muffler that way.
I just did Flowmaster FlowFX on my week old 1500 Rebel.
For me its a nice balance of deep tone, no drone but comes alive if you put your foot into it. Cab is still very comfortable sound level for music or conversation. The sound level is enough to know it's there without blowing up your neighbors. Personally, I wouldn't want it any louder.
And - I did it myself in about an hour and the install is spot-on.
Flowmaster FlowFX
This seems to be what I'm looking for. My last truck I did a cat-back but don't really want to spend a lot of $ modifying a brand new truck. And I don't want to loose my stock black exhaust tips! Anyone have a sound or video clip of the FlowFX?
Cheers,
This makes sense. I'm considering going with a custom installed MF 18" as it may knock another couple % off of the loudness increase.
Thank you for confirming fair cost of custom install, and also for the recommendation!
Anyone have a comment on the Flowmaster Super 40? It's just a couple steps up in the aggressive chart for Flowmaster, but it is chambered. I'm wondering if its chambered design plus the 3 resonators in the truck already will yield more tame sound than FlowFX/MF. The custom shop said that it is wider design so should have a deeper tone and the chambers help more with drone. I've only seen a couple comments on the Super 40 with this truck, and no comparisons or before/after vids...
Anybody get a MF 19433 Direct Fit yet? W/ 20% off at hottexhaust it would be cheaper than the B2 MF. Wondering what the sound comparison is like given the different muffler styles. Skinny & straight vs oval
for those getting the straight through packed mufflers are you noticing any loss of low end torque? And if so I wonder if the chambered mufflers would be better for low end torque.
This doesn't show to be out yet. Seems like a reasonable option though.
Looks like Magnaflow added a video. Sounds more on the aggressive side to me.
This is the only video on a DT that i've been able to find, and its only a start up
Thanks, would be nice to know whether that video has the resonators removed or still intact...doesn't appear the poster replies to video comments though.
I went with the FlowFX. Instead of getting the "direct fit" version, I just had my muffler guy order the muffler and install it.
Cost me $182, out the door, including tax. Took less than a half hour. Beats hell out of $310, and doing it myself.
Seemed like a Win-win. :D
The sound?
The best way to describe it is that it sounds similar to stock, only more-so. Has a nice rumble when you're driving easy. Talks when you hammer it. There is no drone to speak of. Based upon the frequency, I actually find MDS mode to be less obtrusive than V8 mode, but neither is objectionable.
My wife couldn't really tell the difference between the FX and stock. (But there is a difference.)
The sound?
Wow, that's a fantastic deal! Sounds like you got the best of both World there.
Added the flowmaster flowfx direct fit muffler today.
I am very pleased with the sound. Slightly quieter than I would have thought but still very good and fits what I wanted. Which was a little growl and rumble with no drone and still a quiet interior.
One thing with the install I wish I had done different was to go to the local auto parts place and rent a exhaust tubing cutter instead of using a sawzall. The blade must had started to turn part of the way through the cut and it ended up being angled (cut a little more off the factory pipe than should have). I think the blade I was using was a little too long and flexible. It still worked fine. And the muffler went on the factory pipe fine. But there was a very slight gap that you could see through the slits in the flowmaster pipe on the short side of the slanted cut. The clamp covered it 100% and no exhaust leak at all. But I wish I had been more careful.
