Cmerkert
Oh, and do you know if they make them to fit Rambox beds?
I have a bedslide in my rambox. Fits perfectly... Less than 1" clearance per side. $900. Installation was 15 minutes... Make sure it's straight. 4 bolts.Oh, and do you know if they make them to fit Rambox beds?
Wow!!
The bedslide looks great. I have seen them on fifthwheels motorhomes in the under belly and they make it all easily accessible. You lose a little weight but the reality is if you are putting taller stuff in the back, you probably have to open the cover anyway. I pack my bed with 2 generators, burn barrels and firewood and gas for camping so this may be a great add-on.
How much was it?
Where did you get it?
Did you install it?
Easy job?
Mine has the whole rail system. I wanted that to tie stuff down to and hold stuff on the bed.What's the difference between the Bedslide S and the 1000 Classic. Gotta me more than silver vs black
Yes, the back and side rails. makes it easy to toss on a bungy or strap or cargo net, etc for your load.You mean the side rails? The sliding bed is the same, just rails included in Classic 1000?
What lift/level kit did you go with?Wheels n tires!
22 x 10 Black Rhino Warlords with 33 x 12.5 x 22 Toyo Open Country M/T
I decided not to lift it, just keeping it stock. No rubbing at all so looks like I'm all good with its current height.What lift/level kit did you go with?
That is BEAUTIFUL!!! ...Mind sharing the cost info? ...How long were you without your truck? I live near Braselton, and may check them out.Picked up my truck from having the ceramic coating installed! Gtechniq Crystal Serum Ultra, installed by Zero Defects in Braselton, GA.
Where did you pick that up?Not the best pic
Sent from my MI MAX 3 using Tapatalk
Got it off eBay.Where did you pick that up?
