I was considering those over my OEM ram mud flaps that accumulate ton of mud. Actually it was 6 lbs. but whos really countingGot my new Weathertech mudflaps installed just in time for the rain. So much quieter with the nerf bars in the wet now. Can't even hear them, before they were super loud any time I hit any water.
Steam cleaner or good 'ol elbow grease?
a little water spray (light) from hose, a little spray cleaner and brush. Then spray a little detailer and let dry. Man does this engine compartment collect dirt/dust. I do put plastic bags over battery and generator. everything else gets wet. Maybe 15 mins ..Steam cleaner or good 'ol elbow grease?
So, Elbow grease. It does look great. Ever tried a steam cleaner? Works wonders without all the brushing and rubbing.a little water spray (light) from hose, a little spray cleaner and brush. Then spray a little detailer and let dry. Man does this engine compartment collect dirt/dust. I do put plastic bags over battery and generator. everything else gets wet. Maybe 15 mins ..
Huh, I foam cannon an pressure rinse mine.Steam cleaner or good 'ol elbow grease?
You in West Knoxville? I'm NOT a stalker but that's what a stalker would also say...Huh, I foam cannon an pressure rinse mine.
I m in the general area too.You in West Knoxville? I'm NOT a stalker but that's what a stalker would also say...
I have not. although like I said, 15 mins tops to do he whole thing . Just a fast light brush around, nothing too intense.So, Elbow grease. It does look great. Ever tried a steam cleaner? Works wonders without all the brushing and rubbing.
Don't you worry about getting the electronics and electrical connections wet?Huh, I foam cannon an pressure rinse mine.
what’s up with these front axles? I ain’t got no lift on it. Now I gotta get a new passenger output shaft.
Also, just got 210K miles on my ‘20. Having the water pump and belt tensioners changed.
Outside of the dang axles, I’ve been pleased. Suggestions on aftermarket?
Everything under the hood is sealed. No worriesDon't you worry about getting the electronics and electrical connections wet?
Trakmotive, buy from Rockautowhat’s up with these front axles? I ain’t got no lift on it. Now I gotta get a new passenger output shaft.
Thanks. I was not aware of that. Eons ago (1991), I had a Ford Ranger on which I used a pressure washer under the hood, which caused me a massive headache. For the past 30 years, I've been afraid to do it again. I've been using a steam cleaner for the past 10 years or so, and it works reasonably well, with a little wiping up in some areas.Everything under the hood is sealed. No worries
