I just installed a set of Core 4x4 rear end links i purchased a few months ago. I ordered a set for a 2 inch lift, but went with Icon 1.5 inch springs instead. My set came with the extra bushing sleeves to use the frame mount. No spacers either.
From my experience just now:
Provided bolts for top mount to frame were a tad too long. I installed the provided washers on both sides of the bushing then threaded the bolt into the frame mount.
Passenger side sat and tightened nicely. Driver side seemed just a hair longer and wouldn't tighten down. I ended up placing another washer to remedy that. Install went fairly. I swapped out the sleeves using the smaller sleeve to push out the bigger one with a mallet at the same time pushing in the new sleeve. Loaded the bushings up with grease and torqued to spec.
I guess my concern is, are they too long? And if they are, what is the adverse affects, if any? Took it for a quick drive around the neighborhood and it rides fine. Doesn't feel weird or anything.
First pic is with stock end links, all pics after are the Core end links. Does the swaybar position look okay?
View attachment 160939View attachment 160940
