eye exaggerate
- Dec 18, 2021
I had a guy come out and re-dye my driver seat where it was peeling. Looks new again.
I’ve done it and it is SUPER simple. The OEM glass is expensive but worth every penny if you ask me.how was the process? i been wanting to do passenger side with heated and auto dim but dunno if it's worth the process.
I looked at my truck today and thought - despite the many problems I’ve had and still have with it, it’s a damn nice looking vehicle
It is super expensive, that’s why I went with aftermarket without the dimming feature to start. I then found a set of used oem mirror glass with heat, blind spot, and dimming for cheap on eBay, so I pulled the trigger. So much happier this way.I’ve done it and it is SUPER simple. The OEM glass is expensive but worth every penny if you ask me.
Ingenuitive painting set up
Haha yeah next purchase is the entire orange core 4x4 kit. UCAs, LCAs, Panhard bar and Links. Actually the only reason I’m tryin this nonsense with the hellwig. HahahNow you need some good end links...
Haha thanks. it’s required a little more flexibility than I have at this stage in life. I wish it were higher. But ya do what ya can with what ya got I guess.Ingenuitive painting set up
I ha e hung several things off my garage door tracks for painting/powder coating projects.Haha thanks. it’s required a little more flexibility than I have at this stage in life. I wish it were higher. But ya do what ya can with what ya got I guess.![]()
gotcha. when you say "fish the wires through the glass" can you elaborate on that? thank you!Pretty easy. I took the whole mirror off the truck. Pop the glass out and fish the wires through from the glass to the plugs already there and add the needed connections and reinstall. Need to use Alfa to activate. I took my time and had both done in under 2 hours
ahhh. ok im gonna see how much I can get them for before going LKQ and ebay.I’ve done it and it is SUPER simple. The OEM glass is expensive but worth every penny if you ask me.
Through FROM the glass. The glass has wires attached. Fish them through and attach to the connectors.gotcha. when you say "fish the wires through the glass" can you elaborate on that? thank you!
gotcha! sorry it's been a long day i missed that "from" lolThrough FROM the glass. The glass has wires attached. Fish them through and attach to the connectors.
Of for sure man if you are lucky you can find true OEM ones on eBay that aren’t fake people passing off as OEM mirrors and not as expensive I unfortunately never could though so I bought mine through Mopar.It is super expensive, that’s why I went with aftermarket without the dimming feature to start. I then found a set of used oem mirror glass with heat, blind spot, and dimming for cheap on eBay, so I pulled the trigger. So much happier this way.
Yeah no problem just be careful on eBay A LOT of people try to pass the numbers as factual Mopar mirrors but they aren’t. Those are heat, BSM, and electrochromatic for both driver and passenger. It took me literally like 45 minutes to do both sides.ahhh. ok im gonna see how much I can get them for before going LKQ and ebay.
Can you send part number? I wanna double cheeck in case I order the wrong item lol
done that a few times even though I triple checked fitment on the parts site...
This is just my two cents it may have worked for him but that did NOT work for me at all there is a rubber grommet in there that is really tight and I couldn’t get them through at all so I popped the bottoms caps in the mirrors and tan them through the bottom and it goes right along it and you can squeeze it right next to the grommet to the mirror opening to connect it to the mirror. Just giving more options in case that way doesn’t work for you.gotcha! sorry it's been a long day i missed that "from" lol
appreciate the details!This is just my two cents it may have worked for him but that did NOT work for me at all there is a rubber grommet in there that is really tight and I couldn’t get them through at all so I popped the bottoms caps in the mirrors and tan them through the bottom and it goes right along it and you can squeeze it right next to the grommet to the mirror opening to connect it to the mirror. Just giving more options in case that way doesn’t work for you.
