I changed my front and rear diff oils today with Valvoline 75-90 synthetic. I'm looking into doing the T-case next.![]()
I have the 3.21 open diff with e-locker. Doesn't require anti slip additive. Manual says it's 75-90wt. So we're good!did that last week. super easy and a lot of fun. Don't forget the anti-slip additive Mopar recommends and if you have a different rear-end from standard (mine is 3.92) you have to use a different weight.
I have the 3.21 open diff with e-locker. Doesn't require anti slip additive. Manual says it's 75-90wt. So we're good!![]()
Most synthetics have the additive in it already.I have the 3.21 open diff with e-locker. Doesn't require anti slip additive. Manual says it's 75-90wt. So we're good!![]()
SPECS
- Special limited-slip (LS) additives eliminate/reduce chatter and shudder in limited-slip differentials
Something about the 12.5 tire being too wide for the stock rim and not being able to seal properly.Why would it be a desth trap?
8.5" - 11" wide rims are generally acceptable for those tires.Something about the 12.5 tire being too wide for the stock rim and not being able to seal properly.![]()
And most of the time the additive package premixed in the diff fluids isn't enoughMost synthetics have the additive in it already.
They are 20x9, so still in the safe zone8.5" - 11" wide rims are generally acceptable for those tires.
I'm pretty sure his wheels are 20 x 10.
Sounds just about perfect.
I've never heard any noisy diffs using syntheticsAnd most of the time the additive package premixed in the diff fluids isn't enough
I know for fact, if you don't add additional additives on the Chrysler 9.25 with limited slip, it will not work properly. Has nothing to do with noise, but functionI've never heard any noisy diffs using synthetics
Not at all. Before I go through and do any service, I read the manual and get as much info as I can. I've already driven the truck around and it runs fine. No noises from the rear or the front in 4wd. So far truck seems happy.Hope I didn't offend you, just hoping folks read their manuals instead of just mine or your posts.
You are correct in that the gear oil I used has a additive in it according to Valvoline. However, my 1500 doesn't have the LSD. So the additive isn't required for it.Most synthetics have the additive in it already.
Well, the diff in your Z06 isn't the same as what Dodge uses. I probably have 1000s of passes on my Dakota R/T. But not sure how straight line drag racing is an indicator of how well a limited slip differential designed for slipping in corners really worksI've had that diff in 2 trucks for a total of 325k miles and both worked fine.
Too much LSD additive effects the oils viscosity and decreases oxidative resistance of the oil, which is resistance to oxidation from heat; also causes excessive clutch wear and will burn them up.
On the other hand, too little causes chattering which in turn wears the unit out prematurely or destroys it.
I've got 1000's of passes on my Z06 diff using drag radials
and mobil 1.
I had the diff out for a RPM stage 3 upgrade, diff was perfect, clutches were in great shape but do what works for you.
How did you insure the power lead wire did not get pinched exiting the OE fuse box?Installed my switch panel! Overall really happy with the cleaner look, both inside and under the hood.
Sir. You cannot put that on a “Rebel.” Unless you’re trying to infliltrate the empire.I love it. This was going to be my first mod when I had a Rebel coming. Never got the Rebel, ended up with a TRX that has a different tailgate logo, so now I have this sitting at my house.
OK. Your underhood pic looked like it had a sharply recessed liner, might be the shadows. Mine appears more gradual.No. Plenty of clearance.
