I installed mine yesterday as well!Slow day… removed dealer badging and put on the reflective emblems. View attachment 132119
will doLet me know if those brackets work out. I just ordered a set of pro’s from that site, good find man! Always love a discount.![]()
You dont like your bed do you? The plastic drop ins do almost as much damage to the paint as not having a bed liner at allRam bed liner today, letting the sun relax it into final fit.
the canister takes a good 12 " of bed space or a little more. It is not difficult but not the easiest to remove.Do you think with a cover like this you could get away with leaving it installed and having a dirtbike in the back, or would it need to be removed?
it will work as it is a universal harness, before placing my order I did check that the sku number at quadratec match the sku number 557803 in the baja website and actually my order shipped direct from the baja warehouse. Quadatrec is just a jeep focus website
That's why I went with the X4s. I figured with the 5'7" bed I didn't want top loose 12" of it.the canister takes a good 12 " of bed space or a little more. It is not difficult but not the easiest to remove.
wondering if a roll up kind would be best on your situation. like the bak revolver. probably best fit for the dirt bike and doesn't block the rear window.
fyi the brackets I got from rhrswag.com also free shipping and try the discount code putco might still work for a discount.Awesome I’ll snag a pair and the brackets you mentioned![]()
I really like the x4 but I couldn't pass mine at $450 and these days I don't carry a ton of stuff on the bed or bulky items.That's why I went with the X4s. I figured with the 5'7" bed I didn't want top loose 12" of it.
Does that one lock in with a pin or just snap in?Installed Mopar Ram hitch cover. Looks good and nice quality.
If it's like the Mopar one I have, it's just fun we plug that pushed in. Has a "collar" that goes around the receiver, so when you install the hitch it's still attached to receiver.Does that one lock in with a pin or just snap in?
Don't care if I never see the bed paint again, it's not about the bed, it's about cargo. And unlike the spray-in stuff, this can easily be removed, modified, or replaced.You dont like your bed do you? The plastic drop ins do almost as much damage to the paint as not having a bed liner at all
Just as HSKR said. The cap is friction fit with a retaining strap that stretches around the receiver tube.If it's like the Mopar one I have, it's just fun we plug that pushed in. Has a "collar" that goes around the receiver, so when you install the hitch it's still attached to receiver.
I guess it would depend on the length of the bike. I believe the cover box is about 8 yo 9 inches of space the would subtract ftom the bed lengthDo you think with a cover like this you could get away with leaving it installed and having a dirtbike in the back, or would it need to be removed?
I just think he is trying to tell you that the drop in liners usually cause bed rot. This was years ago. Possibly different today. Definitely looks good and definitely will protect your bed from dings and scratches. Just check to make sure it isn’t wet underneath. They used to trap water which obviously caused premature rust and rotDon't care if I never see the bed paint again, it's not about the bed, it's about cargo. And unlike the spray-in stuff, this can easily be removed, modified, or replaced.
And they scratch the hell out of the bed, rubbing the paint off, which leads to rustI just think he is trying to tell you that the drop in liners usually cause bed rot. This was years ago. Possibly different today. Definitely looks good and definitely will protect your bed from dings and scratches. Just check to make sure it isn’t wet underneath. They used to trap water which obviously caused premature rust and rot
Invert logic. Protecting cargo, not bed.Also if it’s not about the bed why even try to protect it
