UnclJim
Technically it committed suicide!Murderer!
That's not gonna hold up in court...Technically it committed suicide!
Unless that’s Gregor Samsa, I think this qualifies as mothacide, which carries a much lighter sentence.That's not gonna hold up in court...
Here is the hardwire kit that I got which is required for the cam to record while truck is off. I will warn you though that it comes with two fuse taps that will not work. The included fuse taps are for MINI fuses and our trucks run Micro2 and Micro3 fuses. I've included another link below that should work
Rexing Smart Hardwire Kit
Micro2 Fuse Tap
Also, 30mpg for a diesel seems optimistic.Don't forget the added maintenance cost for the deisel in oil and fuel filter changes, as well as DEF refills.
I'm glad someone said this.Also, 30mpg for a diesel seems optimistic.
What area are you in?Selling those rims and tires if anybody is interested
I’m at 29.1 mpg average (pen and paper) with my michelin defender ltx tires on my 22’s and a tuner almost maxed on power level. Getting 30 is doable. Now, the more city driving is sprinkled in (I’m mostly steady, non-city traffic), the lower the mpg. That’s the same for the hemi though.I'm glad someone said this.
Well the gurgle sound I have been talking about over the last week has started to become more frequent as I slow down into a coast.
Here is a new video from today where you can sorta hear it
Thats awesome!I’m at 29.1 mpg average (pen and paper) with my michelin defender ltx tires on my 22’s and a tuner almost maxed on power level. Getting 30 is doable. Now, the more city driving is sprinkled in (I’m mostly steady, non-city traffic), the lower the mpg. That’s the same for the hemi though.
I’m in westchester county ny. 40 miles north of nycWhat area are you in?
My neighbor has a 19 Ram Bighorn Night Edition with the Hemi, he's getting 14.2.....OUCH!
I can get that...if I hyper-mile. But that takes work, and clogs up most highways. Oh, and driving at mid-60s (soft speed, to take advantage of downhills and let momentum carry you uphill) means taking longer to get there.Also, 30mpg for a diesel seems optimistic.
Can you show me where you mounted the switch inside the cab?Swapped out the lower grille and installed a 22” light bar in the front bumper of my ‘19 1500 Laramie Sport.
This preexisting bolt behind the washer fluid reservoir makes for a perfect relay mounting location.
For 12v power to the switch, I used a fuse tap on fuse F35 (Mod Inverter / Mtr Sunshade Sunroof / Mtr Dual Sunroof) in the interior power distribution box. I had already used a fuse tap on F66 (Run - Accessory Feed) for my radar detector, but F35 is also ignition switched.
Highs, lows, fogs (thanks AlfaOBD), light bar
The finished look is very clean and discreet, which is exactly what I was looking for. The light bar and wiring harness is actually recycled from my previous RAM ('13 1500). I had the light bar mounted to a Ranch Hand grill guard for over 5 years with zero issues.
Products used:
Replacement grille - Lower Grille - Mopar (68334531AD)
Light bar - Traveller 7,200 Lumen LED Off-Road Light Bar, EDT-B010
Wiring harness - Traveller LED Light Installation Harness, EDT-A-005
Switch (not pictured because it hasn't arrived from Australia yet) - Billet Automotive Buttons 19MM 'LIGHT BAR' BILLET PUSH BUTTON SWITCH
Mounting brackets - Ebay Lower Hidden Bumper 22'' LED Light Bar Mount Brackets For Dodge 19-21 RAM 1500
Fuse taps - Gebildet 4pcs 12V-24V Add-a-Circuit Micro2 Fuse Tap
