- Apr 11, 2019
You need a $21 VIN license that doesn’t expire for the vehicle.I've been following this (and the other) thread. I don't know much about OBD scanners having never had one. Looking at jscan, it appears that in addition to the Vgate jimmy07 linked, you'd need the security bypass cable. Then a license is required in order to write changes back to the vehicle. Is that correct? Anybody know the cost of the licenses? Is it a one-time fee or yearly?
You’ll need a security gateway bypass if you are going to do anything other than read codes or read information from the vehicle. That means in order to clear the codes, you need a bypass.
HNeekyr Cable Adapter Compatible with Chry-sler 12+8 Programming Cable Connector for Autel DS808 Maxisys Main Test Cable for Autel DS808 Maxisys MS905 MS906 MS906BT MS906S MS908 MS908S Pro https://a.co/d/gQ79gz7
