bucolic
Short answer: with the L-brackets one notch lower on both sides than usual, the effect of the WDH was barely better than not using the WDH at all.
Long answer: I had to lower my L-brackets because I lost the bar used to snap the trunnion bars onto the L-brackets. I could get the driver side bar on the L-bracket myself, but I couldn't get the passenger side trunnion bar even close to the L-bracket. We were leaving on a weekend trip, so I had to get the trailer hooked up; as a result I opted to lower the L-brackets just so I could lift the trunnion bar onto the L-brackets (both sides). I figured that being attached would be better than nothing. Turns out, that's true, but barely. I felt the trailer tugging and swaying as we went over road undulation. The feeling was more like towing without the WDH than it was towing with the WDH.
With a new trunnion bar snap tool in hand, I won't have to deal with the lower position on the brackets again.
Until I lose the tool again, that is.
I wonder if your setup is slightly off. I saw someone at the campground with this hitch and the round bars and he had the same issue. When he hooked up to leave I could see his setup was off as the bars were at quite an angle when, someone correct me if I am wrong, they should be very close to level when properly set up.
So this
![1625842434574.png 1625842434574.png](https://5thgenrams.com/community/data/attachments/99/99267-86a1ec62fd3c52e852606bbd2e017437.jpg)
If they are not level I do think the setup is not correct. The fellow camper at the campground when hitched up the bars on his L bracket were easily 4" high than at the hitch.
I know on my Equilizer hitch moving the L brackets was too much of an adjustment. I wanted to add tension and moved them to do this and the back wheels just spun so one notch on the l brackets was a huge adjustment. I ended up adjusting with the washer and it's amazing the difference just one or two washers make on the hitch head. I rarely need to use the tool to place the bar on the l brackets on mine unless the ground level is way off.
