Jeffjad
Awe c'mon man, you can't do that. Pull that sucker outside and get a little wetLittle teaser. It’s pouring rain and will be all week ☹View attachment 55732
There's the money shot.....looks awesome man! What wheels and offset did you go with. Some day I will be able to afford some wheelsAlright alright, here you go
Thanks man! After months of research and changing my mind a million times, I’m really happy with how it turned out.There's the money shot.....looks awesome man! What wheels and offset did you go with. Some day I will be able to afford some wheels![]()
That looks good! How did the ride change with those tires?Alright alright, here you go
I can feel the bumps a little more on the county road but nothing crazy or uncomfortable, I have them set at 38 psi. The main roads feel smooth. I can definitely hear them, but that's what the radios forThat looks good! How did the ride change with those tires?
Looks to be around 84” to top of shark fin. My garage doors are 96”Do you know how tall your truck is with those wheels and the level? I see that you can get the truck into your garage. Thanks.
Hey Jeffjad, when I was installing the lift this past weekend I thought about your ABS issue and possible causes.There's the money shot.....looks awesome man! What wheels and offset did you go with. Some day I will be able to afford some wheels![]()
Hmmmm, I will have to look at the top two clips on the driver's side behind the plastic because I never noticed them. I left the clips for the UCA unattached on both sides when I installed the RC UCAs (nowhere to clip them anyways). What you are saying makes sense because I noticed I get the light more frequently when turning right. I will check it out and get back to you. Thanks for the info JUICEMANHey Jeffjad, when I was installing the lift this past weekend I thought about your ABS issue and possible causes.
When removing the driver side strut and control arm, the instructions say to remove the wheel speed sensor cable clips (similar to passenger side), but to also remove the additional top two clips (behind the liner and only on the driver side) and when reinstalling to also not connect the top two clips at all. I noticed on the driver side there was a lot less slack on the cable and ended up not connecting the clip that attaches to the UCA as well because it would stretch the cable when turning, especially when turning to the right.
Wonder if that is your issue?
Ok so I see what you are talking about in step 36 below (first pic). I checked it out and these clips are behind the strut mount and hold the harness that the speed sensor wire originates from however I don't see how this will give more slack as the speed sensor wire is still clipped in two other places prior to going to hub (second and third pic). The two clips that the instructions refer to were connected on my truck and I just disconnected them. It must be in the instructions for a reason so we shall see when I get to hit some windy roads.Hey Jeffjad, when I was installing the lift this past weekend I thought about your ABS issue and possible causes.
View attachment 55928View attachment 55929View attachment 55930
Yes it was connected to the Mopar UCA prior to swapping them over to the RCs. I def have more slack in it now that it's not connected at the UCA. I haven't had the traction control engage for awhile but I haven't been on a windy back road for awhile either.And also your truck is a good 1/2” higher than me since mine has settled, and imagine that stretched the cable even more prior to you installing the new uca and disconnecting it.
Can you remember if it was connected to the uca prior to you installing the RC UCA?
Now you have me curious why the instructions say to keep those two harness clips disconnected ha. Did you leave yours disconnected? You have to really reach behind the strut to feel for them. When I disconnected them it gave the harness a little more play but not that much.Hey Jeffjad, when I was installing the lift this past weekend I thought about your ABS issue and possible causes.
Hey everybody I apologize in advance is this question has already been asked. But do any of you have a picture of the actual spacer and where exactly does it sit on the shock? Any help would be very much appreciated.
