Would you be able to post the part numbers OPR front spring if you by chance know them. ThanksWell, I went ahead and got the tires I wanted today at least. Now I just need to decide if I want to install the ORP front springs I have sitting in my garage or remove the spring spacers in the back to drop it back down to near level. Or, look for a 1" spring spacers instead?
Your sig says Mopar lift, so it should have the correct UCAs with the improved angle ball joint.Been running this lift with the ORP springs for about 70,000 miles and I'm getting some knocking noises from the front end. Most noticeable when turning at slow speeds, hitting speed bumps etc. I'm assuming its ball joints/ bushings so ill probably overhaul but I remember people mentioning the ball joint on the upper control arm being at the wrong angle due to the springs. Any suggestions on upgrading those control arms with my set up would be appreciated.
I chased a knocking sound for a long time with this same setup and it ended up being the FOX shocks themselves. They need serviced every so many miles per their website. I ended switching to Bilstein shocks, no more knock and better ride overall. I'm not saying that's where your knocking is coming from but that's where mine was. Start by checking your end links to make sure they aren't shot.Been running this lift with the ORP springs for about 70,000 miles and I'm getting some knocking noises from the front end. Most noticeable when turning at slow speeds, hitting speed bumps etc. I'm assuming its ball joints/ bushings so ill probably overhaul but I remember people mentioning the ball joint on the upper control arm being at the wrong angle due to the springs. Any suggestions on upgrading those control arms with my set up would be appreciated.
Did you replace the shocks only?I chased a knocking sound for a long time with this same setup and it ended up being the FOX shocks themselves. They need serviced every so many miles per their website. I ended switching to Bilstein shocks, no more knock and better ride overall. I'm not saying that's where your knocking is coming from but that's where mine was. Start by checking your end links to make sure they aren't shot.
I don't have the mopar lift, but I read through a lot of this thread while researching my own level/lift configuration.Anyone know if the Mopar kit will level the truck? I see some trucks leveled afterward and some very clearly still have the stock rake so unsure of what it will do.
Ultimately just want to level the truck and retain ride quality with quality parts no spacers
That’s the conclusion I was noticing as well. Do you know of any complication or extra wear or ride quality dings that could come from leaving the rear spacers out?I don't have the mopar lift, but I read through a lot of this thread while researching my own level/lift configuration.
In summary, Mopar lifts the truck by 2". It doesn't level it.
Some didn't like the back all jacked-up and pulled the spacers out for a more level appearance.
You won't have any detrimental ride-quality problems. The only risk is being nose high.That’s the conclusion I was noticing as well. Do you know of any complication or extra wear or ride quality dings that could come from leaving the rear spacers out?
This is correct. I can't imagine it causes any issues. It basically becomes a leveling kit at that point.That’s the conclusion I was noticing as well. Do you know of any complication or extra wear or ride quality dings that could come from leaving the rear spacers out?
Then that being the question of is the price tag on the Mopar kit even being worth if I only want the front end components. Wonder if it’s a better/cheaper idea to get the same Fox setup and better UCAsThis is correct. I can't imagine it causes any issues. It basically becomes a leveling kit at that point.
If the front did end up being higher wouldn’t it only be like .5 to maybe an inch?You won't have any detrimental ride-quality problems. The only risk is being nose high.
If a level is all your after just get Bilstein B8 5100 ride height adjustables.Then that being the question of is the price tag on the Mopar kit even being worth if I only want the front end components. Wonder if it’s a better/cheaper idea to get the same Fox setup and better UCAs
If the dealer installs it, you'll preserve any integrity in your warranty.Then that being the question of is the price tag on the Mopar kit even being worth if I only want the front end components. Wonder if it’s a better/cheaper idea to get the same Fox setup and better UCAs
