Updated 2" Mopar Lift/Level Kit - Discussion
So I’m about to order some tires. I think I’m going to go with Toyo Open Country AT3s at 295/55 22 with factory rims. Which is equivalent to 34.8x11.6. I should be able to get away with this with the 2” lift and no orp?
Hey guys,
I've been reading through this thread, I'm having a hard time finding the answer I'm looking for. I currently have a 2.5" level in my 2020. Would I even notice a difference in the height by going with the mopar 2" lift? It's hard to tell in pictures. Truck rides great with the leveling kit currently, it has the spacer above the strut. It's just not quite tall enough for me. A 4" lift seems like way too much, and the Readylift SST seems like it's really bad. Would it be worth it to go to the mopar 2" or stick with the level that's already installed?
Unless somebody else can answer this question. I am waiting on my truck to come in. I am doing the leveling kit(I think it is 2 inches) and the Mopar 2 inch lift.
I would imagine you would see an additional 2 inch lift above what you have now. Plus any bigger tires will add to that as well.
Maybe someone here already has this answer for you.
Hey guys,
I agree with 610srtgang
From what I understand I think you’d want to go with different control arms if you keep the 2” level on the front after the lift.
Also, I think the latest version of the lift removes quite a bit of rake so having the 2” level on the front will likely result in the front end being higher than the rear end.
Any issues running orp springs with this setup retaining the stock 18" rims and 295/75 r18 tires? (metric 34's) Ive read tons and dont see any clearance issues with the UCA but want to ask first.
L.R.
Do you have ORP? If you don’t, I am copying your setup. Your truck looks incredible. What was your exact tire size?
I have regular bighorn suspension no air no off road package just regular 4x4. Tire size 285/60/20 cooper discover at3
Thanks. I like the way truck looks also. Drives great also
Your Truck looks awesome. So Mopar 2” lift, 1/2 spacer on the front (intended to reduce the front rake?) Could you post a couple more pictures? Maybe one with a side view? Thanks.
No spacer on front
Looks good. any rake to it?
Yes little less rake than factory probably raised front 2.25 inches and back 2 inches with mopar 2 inch lift plus increased height with bigger tires. I like level look but don’t like always looking at tip of hood and u also have to adjust headlights so ur not blinding Person in front. I say it has still 1.5 inch of rake
It won't be level. It's going to have rake. But, with the ORP springs the Height/body lines of the hood and front end might make it look nose high. Here's mine with no ORP springs. Imo it looks perfect, with a 34/35 inch tire you'll get 4+" roughly of new height.
Your truck just sold me on this. Was wondering how it would look with the stock 22s and larger tires.
Hello All,
Wanted to create a thread for pictures/discussions about the updated Mopar Lift/Level Kit (Part#: 77072424AB) - available early May for the public.
I luckily was one of the first to receive and can verify that it does sit closer to level than the original Mopar-Fox 2" Lift kits.
(Comparing another Ram side by side with the original 2" Mopar lift)
I will compile some side pictures and get measurements on Monday and post them Tuesday, as there are about 4 posts going around discussing this update.
IF YOU ALREADY OWN A MOPAR 2" KIT - please be advised there is a TSB That will allow you to drop off your Ram should you want the additional 1" in the front.
(I believe is free of charge but will confirm for those when I drop off my truck Monday for a detail)
Hope this thread helps, lets discuss!
Is this kit compatible on the 2022 Ram Rebel? Also would it delete the 1 inch stock lift on rebels for a total of 2inch lift or would it add to the 1 inch for a total of 3 inch lift?
Thank you! Here's a more recent picture. I have 1.5" of rake. But I usually carry weight in the box for work equipment, hunting season etc so I don't mind it.
Tinted with matte black GT decals.
I have the same tire in a 285. Rub in reverse at lock.
Would look awesome
Your truck would look great. If u do it add some pics to forum.
I know this is a 2” mopar lift thread, but I did the Bilstein 6112s at 2.2” with non ORP rear springs. I have 285/65R20s Nitto Recons on stock wheels. These are my clearances for anyone wanting a rough idea of tire clearances.
