When Trying to go into 4-low are you stopped with transmission in neutral?I own a Ram Big Horn 2020. I'm unable to shift to 4wd low. but I'm able to select 4wd H and 4wd auto. when i turn on the truck and select 4wd auto, it will blink for few seconds, and it will show 4wd shift cancelled.
i tried everything. In neutral, P & D. Does resetting by removing battery works?When Trying to go into 4-low are you stopped with transmission in neutral?
We are terribly sorry to hear that this is happening to your vehicle, Akhil. If concerns persist, we'd recommend reaching out to a certified dealership near you. If you need further assistance please send us a private message, we'll do our best to accommodate your needs.I own a Ram Big Horn 2020. I'm unable to shift to 4wd low. but I'm able to select 4wd H and 4wd auto. when i turn on the truck and select 4wd auto, it will blink for few seconds, and it will show 4wd shift cancelled.
